Hi there
im wondering about cooling and temperatures.
i recently bought a new PC and its getting hot when gaming which is okay but im at 83-84C at the average. and i duno to me that seems a bit much
my question is, 1 is that way high temperature for gaming or is that the temperature it is gonna be
and 2 if it is a bit much which cooler would you recommend looking into as a replacement
my setup is
Gigabyte B550 Gaming X V2
AMD Ryzen 5 5600X 3.7 GHz 35MB
Gigabyte Geforce RTX 3070 8GB GAMING OC 2.0
be Quiet Pure Rock CPU air cooler
and 3 normal chassifans 2 in 1 out
thanks and have a wonderful day.
if this is the wrong category feel free to say so and i will move it.
https://linustechtips.com/topic/1514406-cooling-questions/
It should be lower for a 5600x while gaming
This one Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler (PA120 SE-D3) - PCPartPicker but remember to mount it the right way as it can greatly affect cooling
i will move it.
only mods and admins can do that
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1514406-cooling-questions/#findComment-15996036
Hi there
my setup is
dont get anything from gigabyte, the price is low for a reason.
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
https://linustechtips.com/topic/1514406-cooling-questions/#findComment-15996038
They already have those parts. Don't think they can return them anyways
Total: £1040.95
https://linustechtips.com/topic/1514406-cooling-questions/#findComment-15996040
fair enough
Setup:
https://linustechtips.com/topic/1514406-cooling-questions/#findComment-15996051
It's a bit too warm. First remount your cooler and check if you used enough thermal paste. Then you can try going into BIOS and changing the fan curve, maybe it's too conservative by default.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1514406-cooling-questions/#findComment-15996107
1 hour ago, niljon said:
Hi there
my setup is
Pure Rock is a decent cooler, you should'nt  have that bad temps unless your case is really choked
Check if it's properly mounted, repaste it, check fans speed as well
https://linustechtips.com/topic/1514406-cooling-questions/#findComment-15996113
Thanks for the fine tips everyone
1 hour ago, micha_vulpes said:
I would expect a little better out of the pure rock ( I assume this is the Pure rock 2 120MM, 4 heat pipe, tower cooler)
If this is the PureRock LP, then... That is about what I would expect as it is not much better than the wraith Stealth.
Questions for Further detail :
  1. What do the temps do under an all core load?  My r7 5700X runs substantially "hotter" when it runs something single core, about 10c hotter on a synthetic single core, Vs Synthetic all core workloads. It may peak up to 80C when booting into windows, or computing a new mesh in cad (single threaded use case) but All core Folding at home, or trans-coding video its about 70C.
  2. What Powers is it running? Is it in some sort of auto overclock mode on the motherboard? If you fully uncap pbo it and just let it run ryzen 5000 will basically boost until it hits 85-90c depending on the part.
  3. Is your fan curve set to anything like a silent curve that would slow the CPU fan down?
  4. And then the question of shame because we have all been there : did you peel the protective plastic off the coolers bottom and did you use enough thermal compound? I have definitely done both
 only says pure rock 150W TDP on it so i dunno.
as an answer to 4 im quite certain i did the install correctly with taking of plastic etc. but i will check as i will try a remount and see if it helps.
thanks again all
https://linustechtips.com/topic/1514406-cooling-questions/#findComment-15996240
