I need some help with pc not booting. Been happening for the past month and haven’t changed anything.
I turn on the pc and all fans and LEDs turn on but keyboard and mouse don’t turn on or monitor. I press the power button again to turn it off and still the same, after the third try it boots normal.
When it’s on it works fine,  I’ve done benchmarks and it doesn’t shut off incase it was the power. Seems like it’s when it’s warmed up it works, as if I shut down again it works fine until the next morning.
https://streamable.com/brfel9
https://linustechtips.com/topic/1514147-booting-problems/
Take out a stick of ram then try to boot.
UserBenchmarks: Game 417%, Desk 121%, Work 464%
CPU: Intel Core i5-13600K - 123.4%
GPU: Nvidia RTX 5080 - 354.6%
SSD: WD Blue SN570 NVMe PCIe M.2 1TB - 298.3%
RAM: Corsair Vengeance LPX DDR4 3200 C16 2x16GB - 109.7%
MBD: MSI PRO Z690-A DDR4
Monitor: X32 4k 480hz OLED
https://linustechtips.com/topic/1514147-booting-problems/#findComment-15994013
It could be clocked too high it might not be supported. Xmp profile may need to be disabled.
https://linustechtips.com/topic/1514147-booting-problems/#findComment-15994019
5 minutes ago, Fury98 said:
I’ve had the ram for 2 years now without any issues
then it probabnly died
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
https://linustechtips.com/topic/1514147-booting-problems/#findComment-15994035
Not being critical but the "haven't changed anything" is generally incorrect. In the last month at least one Windows update has been released.
Windows updates often change things and as a result one must double check other areas of the PC hardware to ensure latest drivers etc are also implemented.
As you did not mention system specs there might well be Bios updates for either intel or AMD that you could need to work with newer Windows updates.
https://linustechtips.com/topic/1514147-booting-problems/#findComment-15994114
Windows hasn’t updated yet still need to as I don’t auto update and I’m still on 10. But why does it not work in the morning but at night it boots normal. Plus in the morning it boots after the 3rd attempt. I get if it had issues when it’s on but runs fine
https://linustechtips.com/topic/1514147-booting-problems/#findComment-15994248
sounds more like the PSU is dying on you..
https://linustechtips.com/topic/1514147-booting-problems/#findComment-15994297
19 minutes ago, Fury98 said:
The psu only a year old, if it was dying wouldn’t it have issues when the pc working fine.  Like when I put it on a stress test wouldn’t it randomly turn off?
well. that's true.. with the information it is only 1 year i wouldn't think the PSU is the problem either. since we don't know the rest of the spec's it's basicaly just guessing.
start by disconnecting anything not critical. if it starts better then something connected to it is the problem. if not.. problem is still in CPU/MB/RAM/PSU..
https://linustechtips.com/topic/1514147-booting-problems/#findComment-15994501
Edit I found out why, looked it up again and found solution. Turns out it was windows 10 fast boot mode not working properly. Turned it off boots normal not on the third attempt.
Why would fast boot take longer than normal?  what is the difference with it off, as I don’t see much of a difference apart from the keyboard lights turn on with fast mode enabled.
https://linustechtips.com/topic/1514147-booting-problems/#findComment-15995513
Fastboot basicaly saves an image of your current memory to the disk so it loads windows faster.. hence.. your not realy shutting down when shutting down.  reboot makes your system reset your up timer if you have it turned on.
i had similar issues and as i have 2 nvme's in raid 0 for systemdrive it's better to do a clean boot every time it starts. it only takes about 15 sec anyway, so fastboot is off on my system.. it might actually make it use longer to boot as i have 64GB ram.. 😄
https://linustechtips.com/topic/1514147-booting-problems/#findComment-15995629
Ah okey,  is there a way to reinstall windows without deleting any software or anything I’ve installed. I know there’s the options to keep documents but that always deletes software and it’s such a pain to install everything again
https://linustechtips.com/topic/1514147-booting-problems/#findComment-15995693
you can try the repair function on the installer.
if you get into troubleshooting mode, you can try open cmd prompt and type in powercfg /h off  that should kill the hibernation thus also fastboot.  and just reboot.
https://linustechtips.com/topic/1514147-booting-problems/#findComment-15995708
