This Reddit thread talks about the same issue.
tl;dr passive USB-C extension cables are not part of official USB specifications, so wonky things happen like USB 2.0 requiring a certain orientation.
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
1 hour ago, HitchEdits said:
It was advertised as USB 3.2 on the Amazon listing which is also why I'm confused by the note suggesting USB 2.0
It is expected for newer standards to still support older standards.
So a USB 3.0/3.2 cable is still going to support USB 2.0 devices. You didn't order the wrong item, nor was it advertised incorrectly.
Ah, thanks a ton! This thread clears a ton of it up!
