Budget (including currency): 2200 euros (1200 without the GPU)
Country: Greece
Games, programs or workloads that it will be used for: Will be mainly used for games and video editing.
Other details No peripherals are needed, I am going to be ordering the parts within a week or when I am finally set on the build. I have a 1440p monitor with 170 HZ refresh rate. I think I am set on buying the 7900 XTX Power Color Hellhound which I found for 1000 euros and looking for advice for the rest of the build. The weather is very hot here, so I would like a CPU which is powerful but would not be overheating.
https://linustechtips.com/topic/1513995-first-time-building-a-pc/
Country: Greece
A bit over budget but will be nice
If it's too expensive get a 7700 instead of the 7800X3D
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  (€474.20 @ Amazon Italia)
CPU Cooler: Deepcool AG620 67.88 CFM CPU Cooler  (€75.80 @ Alternate Italia)
Motherboard: Gigabyte B650 GAMING X AX ATX AM5 Motherboard  (€197.49 @ Amazon Italia)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  (€125.47 @ Amazon Italia)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€107.00 @ Amazon Italia)
Video Card: Sapphire PULSE Radeon RX 7900 XTX 24 GB Video Card  (€1057.58 @ Amazon Italia)
Case: Phanteks Eclipse G360A ATX Mid Tower Case  (€107.25 @ Amazon Italia)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€149.90 @ Amazon Italia)
Total: €2294.69
Generated by PCPartPicker 2023-06-18 16:43 CEST+0200
1 hour ago, TimedPing said:
Greetings! what kind of video editing software do you use
Moot point, all major NLE OpenCL support is quite terrible and id avoid AMD if you heavily uses it. But if this is just casual editing and you mainly concern with gaming, then you should mostly be fine.
CPU: Intel Core i7-13700 2.1 GHz 16-Core Processor  (€427.61 @ Amazon Italia)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (€45.90 @ Amazon Italia)
Motherboard: ASRock B760M PG Riptide Micro ATX LGA1700 Motherboard  (€166.92 @ Amazon Italia)
Video Card: Zotac Twin Edge OC GeForce RTX 4070 12 GB Video Card  (€654.00 @ Amazon Italia)
Case: MSI MAG FORGE 100M ATX Mid Tower Case  (€75.50 @ Amazon Italia)
Power Supply: Deepcool PM750D 750 W 80+ Gold Certified ATX Power Supply  (€100.74 @ Amazon Italia)
Total: €1703.14
Generated by PCPartPicker 2023-06-18 17:44 CEST+0200
You can squeeze in a 4070Ti instead but honestly 300 euro extra for only 15% uplift with no VRAM upgrade to increase longevity is so insulting i think id rather use those 300 euro to send a bunch of picket sign of "4070Ti sucks" to Santa Clara.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
@Haldan add Windows 11 to this build.
https://www.skroutz.gr/s/37958987/Fractal-Design-Focus-2-Midi-Tower-Κουτί-Υπολογιστή-με-Πλαϊνό-Παράθυρο-White-TG.html
Fractal Design Focus 2 ATX Mid Tower Case €80,20
Rear exhaust fan for that case.
https://www.skroutz.gr/s/16754282/Arctic-P12-PWM-PST-Case-Fan-120mm-με-Σύνδεση-4-Pin-Black-Black.html
Arctic P12 PWM 120mm 4-Pin Case Fan €5,44
https://www.skroutz.gr/s/41267655/Corsair-RMe-Series-RM850e-ATX12V-v3-850W-Τροφοδοτικό-Υπολογιστή-Full-Modular-80-Plus-Gold.html
Corsair RM850e (2023) 850W 80+ Gold Modular ATX 3.0 Power Supply €122,90
https://www.skroutz.gr/s/42793660/MSI-Pro-B760-Gaming-Plus-WIFI-Motherboard-ATX-με-Intel-1700-Socket.html
MSI Pro B760 Gaming Plus WIFI €185,38
https://www.skroutz.gr/s/40221784/Intel-Core-i7-13700-2-1GHz-Επεξεργαστής-16-Πυρήνων-για-Socket-1700-Tray.html
Intel Core i7-13700 €376,54
https://www.skroutz.gr/s/37466849/Deepcool-AG620-Ψύκτρα-Επεξεργαστή-για-Socket-AM4-1200-115x-1700.html
Deepcool AG620 Dual Tower CPU Cooler €59,90
https://www.skroutz.gr/s/35996072/G-Skill-Ripjaws-S5-32GB-DDR5-RAM-με-2-Modules-2x16GB-και-Ταχύτητα-6000-για-Desktop-F5-6000J3040F16GX2-RS5K.html
G.Skill Ripjaws S5 DDR5-6000 32GB (2x16GB) CL30 €141,55
https://www.skroutz.gr/s/17931876/Samsung-970-Evo-Plus-SSD-2TB-M-2-NVMe-PCI-Express-3-0-MZ-V7S2T0BW.html
Samsung 970 Evo Plus 2TB M.2 NVMe SSD €114,58
https://www.skroutz.gr/s/40243360/MSI-GeForce-RTX-4070-Ti-12GB-GDDR6X-Ventus-3X-OC-Κάρτα-Γραφικών.html
MSI GeForce RTX 4070 Ti Ventus 3X OC 12GB Video Card €841,65
Total: €1928,14 inc VAT
A better look at those components.
https://www.fractal-design.com/products/cases/focus/focus-2/white-tg-clear-tint/
https://www.msi.com/Motherboard/B760-GAMING-PLUS-WIFI
https://www.intel.com/content/www/us/en/products/sku/230490/intel-core-i713700-processor-30m-cache-up-to-5-20-ghz/specifications.html
https://www.deepcool.com/products/Cooling/cpuaircoolers/GAMMAXX-AG620-Dual-Tower-CPU-Cooler-1700-AM5/2022/15900.shtml
https://www.msi.com/Graphics-Card/GeForce-RTX-4070-Ti-VENTUS-3X-12G-OC
