PC HELP!
Solved by JJIN1025,
Issue should be resolved now. I think updating the BIOS along with manually downloading the Grpahics Driver was the solution. I saw on the Bios update notes that it improved memory performance which definetly helped considering my memory wasn’t on the QVL list. Had to order online because the Microcenter near me didn’t have the compatible ones
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
