Hello guys I hope you can help me I'm really desperate and don't know any solution I have an i9 13900kf and a 4090 ram 64 GB sticks my games run very smoothly for 5 minutes but after that you feel the mouse movement changes very heavy and it  feels like i'm playing with 60 hz all of a sudden do you maybe have a solution what could be the reason i'm really crying but just want to play 😭😭
https://linustechtips.com/topic/1513279-gaming-problem-13-generation/
Latest Bios? Ram running XMP? Which resolution?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Temps ? Could be throttling, the 13900K is a nuclear furnace
2 minutes ago, sHaXx said:
everything looks ok
ok but where are the temps???
use sensors only mode and check temps
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
This
run a stress test with it open in cinebench
Setup:
Ok first of all, when posting here please post full system specs, motherboard, cpu, ram speed etc. Could it be because you got a Asus motherboard and is using Armoury crate? (the spawn of evil software from Asus). Go to BIOS and disable armoury crate, save and exit (F10), after reboot. Go to and download Armoury Crate Uninstall Tool https://www.asus.com/supportonly/armoury crate/helpdesk_download/
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
Just now, sHaXx said:
Yes game no cinebwnsch
50C on a 13900 with a game open is bascicaly imposible.
Setup:
3 minutes ago, DoctorNick said:
Okay, zunächst einmal, wenn Sie hier posten, posten Sie bitte die vollständigen Systemspezifikationen, Motherboard, CPU, RAM-Geschwindigkeit usw. Könnte es daran liegen, dass Sie ein Asus-Motherboard haben und eine Armory-Kiste verwenden? (die Ausgeburt böser Software von Asus). Gehen Sie zum BIOS und deaktivieren Sie Armoury Crate, speichern Sie es und beenden Sie es (F10) nach dem Neustart. Gehen Sie zu Armory Crate Uninstall Tool und laden Sie es herunter: https://www.asus.com/supportonly/armoury crate/helpdesk_download/
Intel Core i9-13900KF, 24x3.0 GHz (Raptor Lake)
 Cooler MasterLiquid ML360 ARGB V2, Wasserkühlung, beleuchtet
 64GB DDR5-5600 MHz (2x32GB), Corsair Dominator Platinum RGB
 NVIDIA GeForce RTX 4090, 24GB GDDR6X
 Asus  z690 p Mainboard
 Samsung 980 PRO NVMe 1TB Heatsink (V8P1T0CW) M.2 PCIe 4.0
 ATX-Midi Cooler Master HAF 500, Tempered Glass
 be quiet! Straight Power 11 1200W, 80+ Platinum,
1 minute ago, sHaXx said:
Intel Core i9-13900KF, 24x3,0 GHz (Raptor Lake)
 Samsung 980 PRO NVMe 1 TB Kühlkörper (V8P1T0CW) M.2 PCIe 4.0
 ATX-Midi Cooler Master HAF 500, gehärtetes Glas
 be quiet! Straight Power 11 1200 W, 80+ Platin,
I have not installed Armory Crate, it always asks me when I reinstall windows, then I click on no, do not install
asus still has a backlogged software or files running in the background anyways, if this pops upo to install then the installer is on tr pc, delete it
Setup:
Do you think that my cpu doesn't work properly with such a temperature
i think u got rlly lucky with silicon or the game wasnt heavy at all
Setup:
