Need help pinpointing a bottleneck
Solved by CommanderAlex,
5 minutes ago, RuNeN00b said:I've also considered my memory as an issue, as I'm running mismatched 4GB sticks in dual-channel and one 16GB stick in single. I also have a somewhat cheap motherboard, so I don't know how much benefit I'll really have from just upgrading my CPU, if that's my issue.
Definitely sounds more like a memory issue here since your running different capacity sticks. Try running just the 2x4 for now and see if there is an improvement. You can also try using DDU to reinstall the graphics drivers.
