Best PC for using Excel
Go to solution Solved by filpo,
16 hours ago, Tom L said:
I was wonder what the best PC build is for heavy Excel use. Next to this I has some questions. For example, does the GPU impact excel? Does a fast SSD impact working with excel? Is it better to have a lot of cores or less cores but higher speed? Is there something else that can impact the speed?
no a gpu shouldn't so igpu should be fine. Go for this
PCPartPicker Part List: https://be.pcpartpicker.com/list/YdcnW4
CPU: Intel Core i9-13900K 3 GHz 24-Core Processor  (€614.95 @ Megekko)
CPU Cooler: ARCTIC Liquid Freezer II 420 A-RGB 68.9 CFM Liquid CPU Cooler  (€143.85 @ Megekko)
Motherboard: Gigabyte Z790 UD AX ATX LGA1700 Motherboard  (€227.95 @ Megekko)
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6600 CL34 Memory  (€161.92 @ Azerty)
Storage: Samsung 980 Pro 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€89.90 @ Tones.be)
Case: Lian Li LANCOOL III ATX Mid Tower Case  (€158.85 @ Megekko)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€163.85 @ Megekko)
Total: €1561.27
Generated by PCPartPicker 2023-06-13 16:38 CEST+0200
Budget (including currency): 1500€ (more or less the same in US dollar)
Country: Belgium
Games, programs or workloads that it will be used for: Heavy use of excel
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  I was wonder what the best PC build is for heavy Excel use. Next to this I has some questions. For example, does the GPU impact excel? Does a fast SSD impact working with excel? Is it better to have a lot of cores or less cores but higher speed? Is there something else that can impact the speed?
https://linustechtips.com/topic/1512834-best-pc-for-using-excel/
One thing go note is that most cpus that have higher core count also are higher binned and have higher single core speed than the lower core variants so it won't be the case where the lower core variant would be better unless there is some really weird scheduling issue or other software glitch making it not play nice with the higher core count.
Total: €1561.27
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://www.anandtech.com/show/17601/intel-core-i9-13900k-and-i5-13600k-review/8
Based on this review it looks like ryzen 7000 series cpu scores highest in the excel benchmark so I guess you would want the one with the highest score if you are looking for the best cpu for excel.
The biggest thing that affects large excel sheets is memory, if you have lots of equations and/or macros then CPU speed can start to mater. Basically anything with an i5 and 16-32GB of RAM should be fine. For a desktop you shouldn't need to spend more then $500-$700 us. Personally I would probably just get an old Dell or HP mini off eBay leftover from a business.
Edit: spelling/grammar
Total: €1561.27
Go for this
This is too extreme, like wasting money territory.
Dude's not gonna OC, why get a Z790 board... expensive SSD... gucci case when no gucci needed...
I think a fast 13600K would be plenty on a 60 board.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
only mesh one that fits a 420 rad, also its a very good case (high performing)
expensive SSD.
for a gen 4 ssd with dram cache its actually reasonable. But I agree there are cheaper options,  but would only save about 30 euros
They might, you never know. And even a good b760 board is again only 30 euros less
depends, some things on excel get really demanding so if he's on that end of the spectrum he might want it
Total: £1040.95
16 minutes ago, 8tg said:
This depends on the scale of excel usage, current excel is multithreaded and benefits greatly from core count.
As well load times are affected by storage, and search times are heavily affected by ram speed and capacity.
All of this in context to after a certain point, digging through a 700k line table of plain information is not nearly as hard on a system as mass scale calculations done on that 700k line table. If you’re doing stuff like that, focus down cpu/ram/storage. If you’re not hosting the file locally you’d also want a decent network connection for a shared workbook to synchronize properly.
The gpu will do nothing for excel, if that’s the primary use case of this system then igpu is plenty for you, if you just want to power a bunch of excel across multiple monitors get a GT1030.
My take on the idea:
https://pcpartpicker.com/list/bQvywc
Basically focusing the 13900 non K, decent ram, high end ssd, otherwise just solid component choices considering the budget.
Going 13900 non K since the benefit here will be core count more than single core performance, which allows for not starting a house fire and using a quieter air cooler.
Closed side Define 7 since nothing pretty is being made here, obviously that kind of stuff is entirely subjective and it’s just my recommendation for a case.
Why is everyone suggesting the i9 when based on benchmarks ryzen 7000 series does better? Also 7000 series cpus have igpus now so it's not like you couldn't go the 7000 series cpu without a gpu. Just get a 7900x and you can easily blow the i9 out of the water.
12 minutes ago, 8tg said:
I don’t use and don’t like amd.
Ok so give worse advice because you don't like a brand is kinda dumb. I mean at the very least it would be good to acknowledge the other option with your suggestion. Personally I don't see why I would go Intel when they need an entire ac unit to cool their nuclear reactor they call a cpu and it preforms worse in the excel benchmark than the AMD counterpart.
CPU: *Intel Core i5-13500 2.5 GHz 14-Core Processor  (€272.95 @ Megekko)
CPU Cooler: *Deepcool AK500 68.99 CFM CPU Cooler  (€58.85 @ Megekko)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  (€172.95 @ Megekko)
Memory: *G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-5600 CL36 Memory  (€116.95 @ Bytes At Work)
Storage: *Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€104.95 @ Megekko)
Case: *Fractal Design Pop Air ATX Mid Tower Case  (€90.85 @ Megekko)
Power Supply: *Corsair RM550x (2018) 550 W 80+ Gold Certified Fully Modular ATX Power Supply  (€107.90 @ Azerty)
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit  (€118.85 @ Megekko)
Total: €1044.25
Generated by PCPartPicker 2023-06-13 18:54 CEST+0200
Total: €925.40
Generated by PCPartPicker 2023-06-13 18:53 CEST+0200
Is everyone going to suggest Intel even when the r5 5600x beats the i9 13900k in the excel benchmark? Some people are crazy I guess 🤷
