Budget (including currency): RON
Country: Romania
Games, programs or workloads that it will be used for: Rocket League, Csgo, Forza Horizon 4, Davinci Resolve 18, Photoshop etc.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Looking for a decent build for 1440p high refresh rate, pc build under 5500 RON. Would prefer some rgb if possible. It would be much appreciated if parts list will be linked too.
https://linustechtips.com/topic/1512250-first-build/
Country: Romania
Do you already have a monitor or is a monitor to be included in the budget?
https://linustechtips.com/topic/1512250-first-build/#findComment-15979984
@NotFutureProof find a graphics card to put into this build. I can't find one for your budget that would do good at 1440P.
https://www.pcgarage.ro/carcase/endorfy/regnum-400-argb/
ENDORFY Regnum 400 ARGB ATX Mid Tower Case 491,15 RON
https://www.pcgarage.ro/surse/corsair/rm750e-80-plus-gold-750w-1/
Corsair RM750e v2 750W 80+ Gold Modular ATX Power Supply 668,24 RON
https://www.pcgarage.ro/placi-de-baza/gigabyte/b660m-gaming-x-ddr4/
GIGABYTE B660M GAMING X DDR4 649,36 RON
https://www.pcgarage.ro/procesoare/intel/alder-lake-core-i5-12400f-25ghz-box/
Intel Core i5 12400F 799,99 RON
https://www.pcgarage.ro/coolere/endorfy/spartan-5-max-argb-1/
ENDORFY Spartan 5 MAX ARGB CPU Cooler 134,61 RON
https://www.pcgarage.ro/memorii/gskill/aegis-32gb-ddr4-3200mhz-cl16-135v-dual-channel-kit/
G.Skill Aegis DDR4 3200MHz 32GB (2x16GB) CL16 366,36 RON
https://www.pcgarage.ro/ssd/western-digital/black-sn770-1tb-pci-express-40-x4-m2-2280/
Kingston NV2 1TB M.2 PCIe 4.0 x4 NVME SSD 219,99 RON
Total: 3329,70 RON
https://linustechtips.com/topic/1512250-first-build/#findComment-15980410
Country: Romania
Hey neighbor, Bulgaria here 🙂. The problem you have is the same we have here - absolutely atrocious prices of the new GPUs. What i would suggest is take a look at the 2nd market for a GPU, get the best one that you can have. That is unless you are willing to shop from Germany or The Netherlands where the prices a better. So once you decided what GPU you want, you can build a system around that. But here is try at a brane new system from pcpartpicker anyway:
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  (766.90RON @ PC Garage)
Motherboard: ASRock B550M Phantom Gaming 4 Micro ATX AM4 Motherboard  (496.88RON @ PC Garage)
Memory: G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (338.44RON @ PC Garage)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (358.89RON @ PC Garage)
Video Card: Sapphire PULSE Radeon RX 6750 XT 12 GB Video Card  (2211.89RON @ PC Garage)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (501.89RON @ PC Garage)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (728.22RON @ PC Garage)
Total: 5403.11RON
Generated by PCPartPicker 2023-06-11 13:33 EEST+0300
However, i would watch EMAG because there are some super cool deals appearing on GPUs. But as i said - check the 2nd hand market because there for the same money you can find 3090Ti or a 6900XT.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
https://linustechtips.com/topic/1512250-first-build/#findComment-15980515
Total: 5403.11RON
Thank you, I checked the 2nd market but no luck. All i could find are 3070s at a reasonable price within my budget. Ive been looking to get the 6700 xt new but for 200 more RON I can go for the 6750 xt.
https://linustechtips.com/topic/1512250-first-build/#findComment-15980558
