Budget (including currency): £1000 - £1150 (excluding peripherals) - GBP
Country: UK
Games, programs or workloads that it will be used for: Mostly video games, nothing brand new. I want to replay some of the games I have played from the mid2000s to 2015. Don't care much about playing new games on Ultra settings however, I'd like to try some of them and wouldn't mind medium or low settings on brand-new games.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I need everything from tools to display as I'm starting fresh. I only want to spend around £1000 on the working PC itself excluding everything else.
https://uk.pcpartpicker.com/list/DqZj3y
Does this look good, what issues could arise?
Thank you!
https://linustechtips.com/topic/1512229-first-pc-build/
It seems fine, but in my opinion:
- I would spend a little bit less in the motherboard or perhaps looks for one with more PCI-E slots
- I would put another NVME to use as a bootdrive for my OS + the Software I use. Recently my Samsung Evo 970 failed, and thanks god it was just the SO and few software, I have a harddrive for important file and a 1TB NVME for games
https://linustechtips.com/topic/1512229-first-pc-build/#findComment-15979710
Country: UK
Thank you!
That set of RAM you chose is going to be a bottleneck. You want either DDR4 3200 or DDR4 3600.
https://linustechtips.com/topic/1512229-first-pc-build/#findComment-15979730
PCPartPicker Part List
CPU: *Intel Core i5-12400F 2.5 GHz 6-Core Processor  (£148.99 @ MoreCoCo)
CPU Cooler: *Deepcool AG400 BK ARGB 75.89 CFM CPU Cooler  (£31.03 @ MoreCoCo)
Motherboard: *Gigabyte B760 GAMING X DDR4 ATX LGA1700 Motherboard  (£125.23 @ Amazon UK)
Memory: *Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (£62.98 @ Amazon UK)
Storage: *Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (£81.90 @ Amazon UK)
Video Card: *Gigabyte EAGLE GeForce RTX 4060 Ti 8 GB Video Card  (£389.99 @ AWD-IT)
Case: *Fractal Design Focus 2 RGB ATX Mid Tower Case  (£70.97 @ Box Limited)
Power Supply: *MSI MPG A750GF 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£94.44 @ Amazon UK)
Case Fan: *ARCTIC P12 56.3 CFM 120 mm Fan  (£8.73 @ Box Limited)
Total: £1014.26
Generated by PCPartPicker 2023-06-10 19:45 BST+0100
https://linustechtips.com/topic/1512229-first-pc-build/#findComment-15979732
CPU: Intel Core i5-13600KF 3.5 GHz 14-Core Processor  (£278.00 @ Amazon UK)
CPU Cooler: ID-COOLING SE-914-XT 45.8 CFM CPU Cooler  (£29.99 @ Amazon UK)
Motherboard: MSI MAG B660M BAZOOKA DDR4 Micro ATX LGA1700 Motherboard  (£129.99 @ Amazon UK)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (£62.98 @ Amazon UK)
Storage: Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (£81.90 @ Amazon UK)
Video Card: Sapphire PULSE Radeon RX 6700 XT 12 GB Video Card  (£328.50 @ Amazon UK)
Case: Fractal Design Focus 2 ATX Mid Tower Case  (£69.98 @ Amazon UK)
Power Supply: Deepcool PM750D 750 W 80+ Gold Certified ATX Power Supply  (£93.84 @ Amazon UK)
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fan  (£10.99 @ Amazon UK)
Total: £1086.17
Generated by PCPartPicker 2023-06-11 04:17 BST+0100
Youll want to undervolt the card to match the 4060Ti power consumption but this would perform a neck better than it.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1512229-first-pc-build/#findComment-15980213
Country: UK
Thank you!
Idk how much you want to spend on peripherals, but I made this list for ya.
Better to go with solid B550 motherboard, and a RTX 3060 will play those kinds of games just fine too.
https://uk.pcpartpicker.com/list/YQbxyK
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  (£124.50 @ Amazon UK)
CPU Cooler: Noctua NH-U12S redux 70.75 CFM CPU Cooler  (£49.95 @ Amazon UK)
Motherboard: MSI MAG B550 TOMAHAWK MAX WIFI ATX AM4 Motherboard  (£154.48 @ Ebuyer)
Video Card: MSI GeForce RTX 3060 Ventus 2X 12G GeForce RTX 3060 12GB 12 GB Video Card  (£278.00 @ Amazon UK)
Case: Fractal Design Pop Air ATX Mid Tower Case  (£76.36 @ NeoComputers)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£114.63 @ NeoComputers)
Monitor: MSI Optix G242 23.8" 1920 x 1080 144 Hz Monitor  (£188.99 @ AWD-IT)
Keyboard: Razer Cynosa V2 RGB Wired Gaming Keyboard  (£54.99 @ Amazon UK)
Mouse: Razer Basilisk X HyperSpeed Wireless Optical Mouse  (£39.90 @ Amazon UK)
Speakers: Logitech Z200 10 W Speakers  (£33.94 @ Amazon UK)
£1260.62
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1512229-first-pc-build/#findComment-15980260
