GPU Upgrade Problems
Go to solution Solved by Timspector,
Finally figured it out! After trying everything I still had no luck, ended up being a one drive issue (I stopped using it a while back). I had to force delete my entire documents folder after removing one drive and then it launched no problem! Thank you for all the help though. I just didn't know where to start!
I recently got a Nvidia 3050 from a friend, opened but unused, and swapped it with my 760 OC. I get display and my computer runs fine for browsing and even the razer Axon program no problem, however when intry and launch elder scrolls online it gets stuck on a black screen immediately. I did do a fresh windows install as well. I've only replaced identical hardware so very new to this.
Specs:
And fx 4300 quad core 3.8GHz
16 gig ram
Corsair 800watt power supply
https://linustechtips.com/topic/1511452-gpu-upgrade-problems/
Specs:
16 gig ram
Could it be the cpu? That thing is ancient
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
https://linustechtips.com/topic/1511452-gpu-upgrade-problems/#findComment-15973884
57 minutes ago, Timspector said:
It ran the game just fine before, not sure why it would be an issue now 😕
if the gpu was sat in a box for a few months, drivers could be out of date. I know its so basic but driver updates fix more issues than you know! go check it out! can you try launching other titles you have, like csgo or dota or something lighter in weight and older.
CPU : 5700x GPU : MSI GTX 1080
https://linustechtips.com/topic/1511452-gpu-upgrade-problems/#findComment-15973991
I've reinstalled drivered twice now 😕 lighter games run, this is the only game I haven't been able too. I've purged all files related to the game and am trying another reinstall. Could there be any issues because the gpu is so much newer than cpu? Previous reply mentioned my cpu's age but I do not know if that's what he meant
https://linustechtips.com/topic/1511452-gpu-upgrade-problems/#findComment-15974106
And you do mean drivers I'd download on GeForce or is there a way to update on the car itself?
https://linustechtips.com/topic/1511452-gpu-upgrade-problems/#findComment-15974108
It's not the CPU that's preventing you from launching the game I believe that's very close to the "recommended" specs for that game.
I know this is going to sound dumb but for sanity sake... just try removing the GPU and then reinstalling it (while the computer is off obviously). See if that helps first. If not --
Driver updates is likely the issue, could be something other than the GPU though. When you did the fresh install of windows did you go thru your Motherboard drivers and ensure the correct drivers got installed? It's often that when you're using older hardware with newer versions of windows that you'll end up with some generic driver that could be causing an issue - Look at your motherboard, go to the OEM website and look for your motherboard model and see if they have any updated drivers on their page, sometimes they do.
https://linustechtips.com/topic/1511452-gpu-upgrade-problems/#findComment-15974444
Download a tool called DDU, look up how to use it, and use it to scrub your registry of any traces of the 760 drivers AS WELL AS ITS ONLY DRIVERS, and perform a clean installation of the latest driver for that card (protip: keep that latest driver on your desktop).
Case: Phanteks Enthoo Evolv X Motherboard: ASUS TUF B450-PLUS-GAMING CPU: AMD Ryzen 7 5800x3d GPU: ASUS GeForce RTX 3080 ROG Strix EVA Edition 12GB OC Cooling: 3x Noctua NF-A14, 1x Corsair ML140 RGB Elite, 360mm EKWB EK-AIO RGB all-in-one cooler Monitors: ASUS TUF Gaming VG27AQ (portrait 2560x1440) & ASUS ROG Strix XG349C (ultrawide 3440x1440) Peripherals: Logitech G915, G502, G733 OS: Windows 11 64-bit
https://linustechtips.com/topic/1511452-gpu-upgrade-problems/#findComment-15974486
https://linustechtips.com/topic/1511452-gpu-upgrade-problems/#findComment-15976725
