CPU AND GPU Temps
Solved by JonS77,
1 minute ago, TheVenom3295 said:shouldn't the gpu temps be higher than the CPU temps
i always thought that gpu temp should be higher and CPU temp must be less comparatively
Depends on the game you're playing, your frame rate, and the type of momentary loud. it's normal for one to be hotter than the other. Your room temps will also affect it a lot. But gaming laptops are for people who can't have a desktop, travel a lot, or need a mobile gaming unit in general. You are compromising performance, aquatics, and temps for a portable experience. That is what you'd get.
