GPU RMA help
Solved by johnno23,
If you still have the box and your invoice then should not be a problem
if you are worried about static anti static bags are easy enough to acquire. Might even be able to get one from a local PC hardware store if you explain your need/
I would just start the RMA process as your GPU is under warranty.
HunterSVK ·
Posted in Troubleshooting0 -
Ozzi ·
Posted in Networking0 -
1
MadManMarsBar ·
Posted in Build Logs0 -
IAmAndre ·
Posted in New Builds and Planning3 -
4
2
Playgb2 ·
Posted in Troubleshooting1 -
2
1
play_circle_filled
Latest From ShortCircuit:
