Scenario:
So I recently upgraded my CPU, Mobo, Case, and Ram from my old system. The plan was to let my friend of mine who is starting to get into pc gaming use my old parts so I finished building my new rig and then built his. I reused my old case, CPU, CPU Cooler, and Ram (All this was already installed on the old case as I was using it up until 2 days ago,). I put in my old 980 GPU and my old Corsair RMX650 and his SSD and go to test the system and I get stuck on a solid white CPU LED. The ram RGB lights up, all the fans spin, but the PC wont go back this CPU LED. The system wont shut off either until I hold down the power button. I know none of these parts are faulty as I was just playing Forza 5 on them 2 days ago. I have tried just about everything I have read and have no idea what the issue could be at this point
List of troubleshooting:
Reslotted CPU (3/4 times)
Reapplied new thermal paste
Changed AIO power from CPU pump to CPU Fan header
Checked CPU and mobo for bent pins
Checked Mobo for any problems
Reslotted all ram (5/6 times)
Tried 1 stick of ram
Bios update via flash drive
Changed from LL120 Corsair fans to standard fans
Tried booting with no SSD
Tried booting with no graphics card
Tried all PCI slots with graphics card
Changed from a RMX650 power supply to RMX850
CMOS Clear w/ battery out for 5 minutes
CMOS Clear with jumping JBAT1 on mobo
Rebuilt the whole PC again
Tried different SATA ports
I looked over just about everything I can possibly think of or read and I am out of ideas of what could be going on. I know all the parts work as I used them 2 days ago and even tested the GPU in my new rig. The specs are below, I would really appreciate any help as he doesn't have any money to spend at the moment on new parts and he really wants to start gaming on PC.
Specs:
i7- I7700k CPU
MSI Z270 Tomahawk Artic edition Mobo
64 GB 3000 MHz DDR4 Trident Z RAM
Geforce GTX 980 (reference card)
Deepcool AIO
Samsung 970 EVO SSD
Corsair 220t RGB Airflow
Corsair RMX850 PSU
https://linustechtips.com/topic/1510152-ez-debug-cpu-white-led/
I did test to see if the CPU is dead by placing my hand on it for a few seconds to see if it heats up. The CPU did get warmer after 10-15 seconds
56 minutes ago, Eugene28 said:
so it stays on cpu light? hmm.. have you checked the socket pins? if there is no issues with sockets pins you should try a different cpu..
I also don't have any spare LGA 1151 CPUs to test unfortunately
https://linustechtips.com/topic/1510152-ez-debug-cpu-white-led/#findComment-15965724
