PCIE Cable confusion
Solved by ImWilly,
1 hour ago, BLTenjoyer said:PCIE power slot has 12 pins on it where the cable he gave me has 8
There are 2 solutions:
1. If you still have spare PSU-PCIe power cable from the box, you should attached both from PSU to be RX 580 GPU
2. If you don’t have spare because lost the PSU box, you’re in luck. I attach link to official be Quiet! Website and they do sell spare cables and it mentions support your PSU (consider yourselves really lucky, because even Seasonic doesn’t offer selling cables on their website)
It has 2 type, one with 8-pin (6+2) and 16-pin (6+2) with ‘ponytail’
I would still suggest to use 8-pin to put less strain on the cable to deliver power
8-pin: https://www.bequiet.com/en/accessories/1445
16-pin:
