I need help
Go to solution Solved by Dutch_Master,
Overheating issues in general relate to insufficient cooling. Reseat the cooler on your CPU, make sure airflow for CPU and GPU coolers is unrestricted, test the GPU in a different, known working system (stress-test!) and make sure all connectors are plugged in correctly. The used GPU can be faulty, hence the stress-test.
Hello I need help about an issue my pc keeps shutting down when its overload also this issue only happen when I play Roblox showcase games like(summer forest) when the wattage goes up to 101w the pc randomly shut itself off i don't understand
my psu is 380w also yesterday i took it to a professional tech he even tested another psu(650w) but still the problem occurs
another  information is that you guys need to know this a used gpu so could this be the reason?
https://linustechtips.com/topic/1509695-i-need-help/
"You don't need eyes to see, you need vision"
(Faithless, 'Reverence' from the 1996 Reverence album)
https://linustechtips.com/topic/1509695-i-need-help/#findComment-15960646
Alright thanks I will do that also About the connectors there is 2 ports in my gpu that are completely broken second and  when I do a stress pc will shut down anyways thanks again
https://linustechtips.com/topic/1509695-i-need-help/#findComment-15960671
