Budget (including currency): 800 euros
Country: Portugal
Games, programs or workloads that it will be used for: 100 % gaming, Warzone 2, Scum, battlefield 2042 and other games
Other details: current build is i7 9700k ( can oc ), 16 gb ram 3200, SSD ( damaged) and a gigabyte 1080 ti.
I would like to upgrade my rig in the 800 euros target. What do you guys recommend? GPU or CPU ( as this last one might be more expensive.
Thanks for your help
https://linustechtips.com/topic/1509189-upgrade-advice/
Country: Portugal
I would upgrade your cpu and mobo to a 5800X3D and a b550 tomahawk
What are your other specs? (ssd, psu, case, fans if any)
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1509189-upgrade-advice/#findComment-15957120
1 minute ago, Papafigos said:
SSD its an old Samsung Evo, but I think it's gone, psu it's a Corsair rm 750x, case is cooler master MB530p, CPU cooler Corsair h110i gt.
I would probably upgrade your cpu, cpu cooler and mobo
PCPartPicker Part List: https://pt.pcpartpicker.com/list/gsYyKp
CPU: AMD Ryzen 7 5800X3D 3.4 GHz 8-Core Processor  (€317.90 @ Switch Technology)
CPU Cooler: Noctua NH-D15 chromax.black 82.52 CFM CPU Cooler  (€114.90 @ Globaldata)
Motherboard: MSI MAG B550 TOMAHAWK ATX AM4 Motherboard  (€169.90 @ Globaldata)
Total: €602.70
Generated by PCPartPicker 2023-05-25 16:49 WEST+0100
Total: £1040.95
https://linustechtips.com/topic/1509189-upgrade-advice/#findComment-15957143
22 minutes ago, Papafigos said:
1080 ti
Oof, I've seen 1080ti's dropping like flies recently. That CPU will keep up with most games these days but if your GPU craps out you're SOL, especially if we hit another GPU bubble. A 3060ti will edge out your current card in performance
Also, welcome to the forums!
https://linustechtips.com/topic/1509189-upgrade-advice/#findComment-15957158
I would need an SSD or nvme as well
you don't need an nvme ssd
Thanks for the fast response, do you think I could get more FPS with this combo ?
if your gpu is being bottlenecked by your cpu then yes
I'm saying this because it's still on the budget.
The 1080 ti is still pretty good nowadays
And the 5800X3D will give you more flexibility for future gpu upgrades
And regarding RAM
And what ram do you specifically have?
Total: £1040.95
https://linustechtips.com/topic/1509189-upgrade-advice/#findComment-15957159
In warzone 2 for eg, I get CPU bottleneck when using mid to low settings with major dips in perfomance. I know it isn't a very optimized game, but it is what it is. 😂
I have 2x 8gb 3200, can't confirm no the model, but it's teamgroup. My mother boar is the rog strix z 390 e gaming.
Basically what I want is to get good perfomance with competitive settings something I can't right now. I use a 1080 display with 144 refresh rate.
https://linustechtips.com/topic/1509189-upgrade-advice/#findComment-15957172
I would upgrade to that 5800X3D, that b550 mobo and cpu cooler I linked above then
Total: £1040.95
https://linustechtips.com/topic/1509189-upgrade-advice/#findComment-15957187
1 minute ago, Why_Me said:
That’ll be bottlenecked pretty hard by the 9700k
Total: £1040.95
https://linustechtips.com/topic/1509189-upgrade-advice/#findComment-15957197
Future wise seems to be the best option as well. My fear is exactly what OddOod said, if my 1080 ti dies I'm screwed. 😂
Honestly it was the best component that I have ever bought ever. They just don't do cards with this quality anymore.
My cooler isn't compatible with AM4 right ? The cooler you recommended, will it keep low temps ? I'm used to liquid.
https://linustechtips.com/topic/1509189-upgrade-advice/#findComment-15957201
It seems pretty old so I doubt it will be compatible. Ye the noctua will keep the temps down on the 5800X3D
Total: £1040.95
https://linustechtips.com/topic/1509189-upgrade-advice/#findComment-15957209
10 hours ago, Papafigos said:
damaged
In what way? Replacing this would be high priority, especially if the data in it is critical, non-replicable, and has no backup.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1509189-upgrade-advice/#findComment-15957811
It doesn't detect the sss in boot, goes straight to bios and no SSD in bios as well. There is no critical data in that drive. It's my gaming SSD. Im afraid my current ram and 1080 ti won't keep up with the 5800x3d
https://linustechtips.com/topic/1509189-upgrade-advice/#findComment-15958459
