So i bought a laptop for school work and stuff, it's from hp and everything was going well untill a random day it decided to stop opening discord, i tried installing notion but it can't open, also now doesn't open github desktop, nor rave.
I tried making a clean windows install from a usb mantaining every app and file i have because it would be a pain in the as to install al of them again one by one
I can't understand the problem because the app shows up for less than a second before vanishing into oblivion and can't be found on task manager
https://linustechtips.com/topic/1509130-pc-problem/
Try running sfc /scannow in command prompt if you haven't already and see if that repairs anything for you.
If that fails, try clearing %appdata% using the steps below.
- Press Windows + R, type %appdata% in Run box, and hit Enter.
- Find Discord folder and right-click it to select Delete to delete it. This should delete AppData.
- Press Windows + R again, type %localappdata%, find Discord folder to delete it. This can delete         LocalAppData.
- Relaunch Discord to see if it can open.
Glowing screen captures,
Sleep eludes, lost in pixels,
Restless eyes still yearn.
-ChatGPT; the greatest poet of our generation.
https://linustechtips.com/topic/1509130-pc-problem/#findComment-15956677
What computer is this exactly?
https://linustechtips.com/topic/1509130-pc-problem/#findComment-15956689
