I have had my computer for about 5 months now and for some reason it just lags at random very frequently. My wifi is fine so I don’t know what could be causing this here are my relevant computer specs
CPU. Intel i9 12 gen
motherboard. Z690 riptide pg
ram. Gskill trident z neo 32 GBs
GPU. Radeon RX 6900 XT
I need help
https://linustechtips.com/topic/1509078-i-need-help/
Is it like a small dip drop of FPS? Usually it is seen from the 0,1% of the FPS
It's hard for me to explain it accurately, but there is a difference between "lag" because of high ping in internet connection and your PC is struggling to process your game.
Try to lower the settings or even enable FSR (depending on your game) and see if there' still a sudden dip of FPS
*EDIT P.S
Could you also share your PC temps?
Your PC might be throttling due to lack of cooling
My System: Ryzen 7800X3D // Gigabyte B650 AORUS ELITE AX // 32GB 6000MHz DDR5 Silicon Power Zenith CL30 // Sapphire Pulse AMD Radeon RX 7900 XT OC with mod heatsink on the metal plate  // Phanteks P300A  // Gigabyte Aorus GEN4 7300 PCIE 4.0 NVME // Kingston NV2 Gen4 PCIE 4.0 NVME //
Seasonic Focus GX-850 Fully Modular // Thermalright Frost Spirit 140 Black V3 // Phanteks M25 140mm // Display: Bezel 32MD845 V2 QHD // Keychron K8 Pro (Mod: Gateron black box ink; Tape mode on PCB and Keycaps) // Razer Cobra Wired Mouse // Audio Technica M50X Headphone // Sennheiser HD 650 // Genius SP-HF180 USB Speaker //
And Laptop Acer Nitro 5 AN515-45 for mobility
Phone:
iPhone 11 (with battery replaced instead of buying new phone for long term and not submitting (fully) to Apple Lord
https://linustechtips.com/topic/1509078-i-need-help/#findComment-15956314
16 hours ago, Overhaul said:
It only happens whenever I play games and I don’t drop in fps my game just freezes for usually a couple seconds
Seems like it's loading assets when you're exploring some area in games, which is usually caused by "slow" storage speed (but not always)
Could you also share what storage you use for OS & game directory?
I used to play on newish title like "Marvel's Spiderman" on laptop with NVME PCIe 3.0 (rated read just about 2GB/s), and it does freeze to load assets such as road, building and so on.
Phone:
https://linustechtips.com/topic/1509078-i-need-help/#findComment-15957974
  • 3 weeks later...
