Budget (including currency): 100€
Country: Germany
I'd like to move from a flimsy usb 2.0 external SD card reader to an internal one. The trouble is, most of the ones I can find online require a free USB 3 header on the motherboard, which is already in use for... Well the USB on the case. I have many SATA headers available so I thought it'd be a better solution. But the only card readers I can find with SATA are offering an eSATA connector and require an additional USB 3 header...
Long story short: do you know of any internal card reader that uses only SATA headers? Is it even a thing?
https://linustechtips.com/topic/1509073-sd-card-reader-with-sata-interface/
Something like this? This is NOT a great solution to be as a regular card reader by the way.
https://www.amazon.com/4-Port-SATA-Adapter-Inch-Housing/dp/B00B4KO0A6
I mean something like that https://www.amazon.com.au/StarTech-com-Internal-Multi-Card-Reader-Support/dp/B011NLXC5O
But with a SATA connection to my motherboard instead of the USB 3 header.
Or if you have any recommendations on how to have both the case USB3.0 AND the card reader connected to one header, I'm all ears
Country: Germany
https://www.amazon.com/Internal-Reader-5-25inches-Multifunction-Accessory/dp/B09377WLPX
https://www.walmart.ca/en/ip/Multi-Function-USB-3-0-Hub-eSATA-SATA-Port-Internal-Card-Reader-PC-Dashboard-Media-Front-Panel-Audio-SD-MS-CF-TF-M2-MMC-Memory-Cards-Fits-5-25-Bay/PRD7DB9IIJ4SRMP?skuId=7DB9IIJ4SRMP&offerId=533F79D26DBE4C64AB69BFCB7016E3B4
You'll be looking for one with eSATA.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Internal USB hub is still pretty much mostly 2.0, but this one by Sabrent im still dont know about. Might be your solution but havent seen many reviews of it being used for data use, mostly RGB stuff.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Granted I haven't tried anything recently, but back before USB 3 I went through a ton of internal card readers and every single one was junk.
All my SD cards are microSD with adapters to full SD, so I just got a tiny UGREEN microSD reader that works great.  It pushes up to 100MB/s.
These two suggestions also require an extra USB3 header, which I don't have
You could get an add-on USB 3.0 PCIe card, or an internal USB 3.0 hub.
