Hey guys, this is a prebuilt bought new in January 2023. The specific prebuilt is a Powerspec g905 from Microcenter. Any idea what could be causing this noise? A full cleaning and reseating of cables has been done so far. The pc will boot up and run just fine, after about five minutes the noise will start.
https://linustechtips.com/topic/1509018-power-supply-issue/
Something hitting a fan probably.  What and which fan you will have to investigate yourself sadly.
Is sound most audible next to the psu?
GPU : RTX 3070 Gaming X TRIO | CPU : Ryzen 5 7600 \ COOLER : Deepcool AK620 | MOBO : ASUS TUF Gaming B650 Plus | RAM : Corsair Vengeance RGB DDR5 16GBx2 6200 MHz \ Storage : Samsung 970 EVO Plus M.2 1TB \ PSU : Corsair TX750M | CASE : Be Quite! Pure Base 500DX Black
https://linustechtips.com/topic/1509018-power-supply-issue/#findComment-15955886
IMG_5731.MOV
Either a cable hitting fan blades or a water pump that has air in it (if you have one).
https://linustechtips.com/topic/1509018-power-supply-issue/#findComment-15955892
that air should have cleared out after 10 min..
the fan would eventualy stop by itself.. when the cable that's hitting it is worn out 😄 .. but still shoddy build to deliver that. unless it's just a bearing that's making the noice.
@O Grizz press lightly on the hub of each fan to stop them to determine what fan is faulty.
https://linustechtips.com/topic/1509018-power-supply-issue/#findComment-15955899
