I had made my build and it was working perfectly, but I decided to watercool it. Now when I go to turn it on I get a yellow light and qcode 15. The system does not post and is only on for about 10-15 seconds before abruptly turning off. Rgb, fans, and pumps all turn on while the mobo is on. I have taken the whole computer apart back to the test bench setup. I did remove the ram heatsink to add them into the the ram waterblock. When I use one stick of ram and move it to the 1st or 3rd slot I recieve qcode c5.
I believe it's a problem with the ram, but do not know how to remedy it.
My specs:
7950x3d
Asus rog strix x670e-e
2x32gb gskill trident z5 neo
Red devil 7900xtx
1tb 990 pro
2tb 990 pro
Evga 1300 Watt p+
64 bit windows 10
https://linustechtips.com/topic/1508670-system-not-posting/
