do i need another drive?
Go to solution Solved by Electronics Wizardy,
I'd get a 4tb nvme drive. Why not, faster and similar price.
I wouldn't run raid here. SSDs are pretty relible, and bckups will keep your data safe in case of failure or issues(id get an external hdd for backups). Yea its not realtime, but the chance of a failure is pretty low.
so this is the build im saving up for rn
PCPartPicker Part List: https://pcpartpicker.com/list/nKWN3y
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  ($297.00 @ Amazon)
CPU Cooler: Noctua NH-D15S chromax.black 82.51 CFM CPU Cooler  ($109.95 @ Amazon)
Motherboard: MSI MPG X670E CARBON WIFI ATX AM5 Motherboard  ($464.99 @ Best Buy)
Memory: G.Skill Trident Z5 Neo RGB 32 GB (2 x 16 GB) DDR5-5600 CL28 Memory  ($119.99 @ Amazon)
Storage: Crucial P5 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($79.98 @ Amazon)
Storage: Crucial MX500 4 TB 2.5" Solid State Drive  ($215.22 @ Amazon)
Video Card: NVIDIA Founders Edition GeForce RTX 3060 Ti 8 GB Video Card  ($150.00)
Case: Fractal Design Torrent RGB ATX Mid Tower Case  ($239.99 @ B&H)
Power Supply: EVGA SuperNOVA 850 GT 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($139.99 @ Best Buy)
Case Fan: ARCTIC P14 PST 72.8 CFM 140 mm Fan  ($11.86 @ Amazon)
Monitor: Dell G2422HS 23.8" 1920 x 1080 165 Hz Monitor  ($169.99 @ Amazon)
Total: $2168.95
Generated by PCPartPicker 2023-05-22 17:45 EDT-0400
will i be okay if I just have the one 4 tb drive or should i get 2 so that I can run raid 1 on them. i kind of already discussed this with @filpo and @bezza... but would appreciate more input
you dont need an aio for anything but i9 cpus or heavy oc jobs just get an nh-d15 or peerless assassin
MARK THE SOLUTION AS SOLUTION
i am 14 so i may be wrong sometimes
@Bob__ is a w
https://linustechtips.com/topic/1508621-do-i-need-another-drive/
Total: $2168.95
are you only gaming?
Why that PSU, from EVGA go G2, G3, or G6
as for data, how much of it is important?  Do you have any other backup solution, raid is not a backup...
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + Thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + PLX88024 PCIe switch (PCIE 4.0 x8 -> 4 x M.2 PCIe 4.0 x4) -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD : LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + flexiDOCK MB014SP-B + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aiyima A80 ( or Aune S6 Pro -> RCA ->  Aiyima A80 ) -> Polk S20e black -> Monoprice stand 16250
HEADPHONES : PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + Kensington VeriMark / PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Razer Wolverine V3 Tournament Edition 8K PC (B0F94C9C43) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox series x controller pc (1VA-00002) + Ravcore Javelin
NET :  Intel E810-XXVDA2 2 x 25GbE SFP28 (PCIE 4.0 x8) -> 2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3) -> Qnap TS-932X-2G + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB -> 2 x FTLX8571D3BCV-IT -> Noctua NF-P14s redux 1200 PWM -> QNAP TR-004
it will be used for gaming, yes, but also workstation (im entering an engineering focused high school next year) and will be used for fusion 360, autocad, reolit, and vs code
@Bob__ is a w
Also, why are you getting a 450 dollar mobo? Scale that back to ~200, 250 tops, and either save the money, or put it towards better components such as faster CPU or GPU depending what matters more for you.
the mobo has the 14 segment post code display which is going to be really helpful for me also the gpu is a deal from a friend which i will use for a while
@Bob__ is a w
Is a post code display worth 250 dollars…….? Probably not. It’s one of those things that used to be cheap, should be cheap, but no longer come on anything except high end mobo’s. But realistically, they don’t matter. They are convenient, but not worth the cost at all.
yh do this.. pretty much what i said. you could always have the seoncnd hdd in the pc and run a script to automoticly back up
how tho
@Bob__ is a w
1 minute ago, bezza... said:
@spaghet rat check the discord
cant on chromebook at shcool
@Bob__ is a w
2 minutes ago, bezza... said:
discord in chrome? or is it blocked.
blocked.
@Bob__ is a w
1 hour ago, spaghet rat said:
how tho
If you want a whole backup daily, then just use veeam for Windows, if Real time file backup, with difference, then you can use freefilesync for it ( just you have to Set it up in it ) it uses ntfs function to search for edited files.
EXTERNAL
HDD/SSD :
