Budget (including currency): 1500 usd
Country: United States
Games, programs or workloads that it will be used for: Light video/photo editing, a little CAD, and gaming
Here is what I have picked out so far. I know I want 32 gigs of ram and at least 2 terabytes of storage. This is my first time speccing a build, although I did build my friends pcs. I am a student and run a drone videography business on the side. I have peripherals except for a gaming monitor so I left budget for it. I mostly play more indie games with some AAA like 2042, and I prioritize resolution and color accuracy over refresh rate. Here's the link to the pcpartpicker. I also would like to stick with a decent Seasonic power supply because I want to upgrade in the future. Let me know anything I may have missed. I'm also open to suggestions for a CPU cooler cause I am not sold on the peerless assassin. Thanks! 🙂
https://pcpartpicker.com/list/gRCRQ6
https://linustechtips.com/topic/1508543-first-pc-build/
For $200 more, this would:
  • Be significantly faster in every game
  • Don't buy a GPU with the intention of upgrading it.  Witha 6900xt, you'll probably never have to upgrade TBH.  You could almost do a 7900xt with this budget, but the 6900xt is still about 70% faster than the 6700xt in every game, which would let you play everything at ultra and a very high resolution, and be excellent in CAD.  If you don't care as much about the AAA games, then you could revert to the 6700xt, but honestlly some indie A3D games are actually pretty poorly optimized and want even more GPU power.
  • I know everyone is freaking out about ASUS boards right now, but this one is fine, it was just a thing with the 7800x3d and it's being resolved.  With a 7600 it'd never matter
  • The 7600 and 7600x are the same CPU, save your money there
  • Seasonic PSUs are good, but they carry a bit of a brand tax.  There are lots of other very high quality PSUs out there.
  • Cooler is black to match the rest of the build, and it's a slightly better cooler, but you could revert if you wanted.  The Phantom Spirit is similar to the Peerless Assis but it has 7 heat pipes instead of 6. IDK why you're not sold on it, it's a dual radiator cooler with a bunch of heat pipes and fluid-dynamic bearing fans for less than half the price of the D15, what's not to love?  But really with a 6 core chip, you could spend $20 on the assassin X and it'd still be plenty of cooling.
PCPartPicker Part List
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor  ($200.00 @ Amazon)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  ($48.90 @ Amazon)
Motherboard: Asus TUF GAMING B650-PLUS WIFI ATX AM5 Motherboard  ($172.99 @ Amazon)
Memory: TEAMGROUP T-Force Vulcan 32 GB (2 x 16 GB) DDR5-5600 CL32 Memory  ($84.99 @ Newegg)
Storage: Samsung 970 Evo Plus 500 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($29.99 @ Amazon)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($126.85 @ Amazon)
Video Card: XFX Speedster MERC 319 Black Radeon RX 6900 XT 16 GB Video Card  ($579.99 @ Amazon)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($94.99 @ B&H)
Power Supply: Phanteks Revolt Pro 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Newegg)
Total: $1448.69
Generated by PCPartPicker 2023-05-22 12:55 EDT-0400
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/1508543-first-pc-build/#findComment-15952062
I would recommend at least a 6800XT instead. 6900XT is only a little more, but 6800XT should be plenty for that kind of work.
https://pcpartpicker.com/list/xDGyJM
CPU Cooler: Deepcool AK400 ZERO DARK PLUS 59.46 CFM CPU Cooler  ($40.98 @ Newegg)
Motherboard: Gigabyte B650 GAMING X AX ATX AM5 Motherboard  ($189.99 @ Amazon)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  ($99.99 @ Amazon)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($109.99 @ Amazon)
Video Card: XFX Speedster MERC 319 CORE Radeon RX 6800 XT 16 GB Video Card  ($539.99 @ Amazon)
Case: Fractal Design Pop Air ATX Mid Tower Case  ($89.99 @ B&H)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
$1370.92
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1508543-first-pc-build/#findComment-15952336
CPU: *Intel Core i5-13400F 2.5 GHz 10-Core Processor  ($199.00 @ B&H)
CPU Cooler: *Deepcool AG620 BK ARGB 67.88 CFM CPU Cooler  ($54.98 @ Newegg)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  ($164.99 @ Newegg)
Memory: *G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($109.99 @ Newegg)
Storage: *Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($109.99 @ Amazon)
Video Card: *Asus DUAL OC GeForce RTX 4070 12 GB Video Card  ($599.99 @ Amazon)
Case: *Fractal Design Focus 2 RGB ATX Mid Tower Case  ($69.98 @ Newegg)
Power Supply: *Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Case Fan: *ARCTIC P12 56.3 CFM 120 mm Fan  ($9.99 @ Amazon)
Total: $1418.90
Generated by PCPartPicker 2023-05-22 13:39 EDT-0400
https://linustechtips.com/topic/1508543-first-pc-build/#findComment-15952373
Hello, I was looking at your list and right now I can't recommend the newer AM5 CPUs from AMD. Until they solve the Voltage issue I'm not comfortable suggesting a new PC with these items. That being said I did stick with AMD and went with the Ryzen 7 5800X3D and paired it with RX 6750XT. I also switched out the PSU for a Thermaltake model because it is the new ATX 3.0 & PCIe 5.0 newer standard plus it's an A-Tier rated PSU and I think the SeaSonic is C or B Tier. The 5800X3D CPU is much better for gaming because of the extra Cache it has and if you turn on the 'SAM" feature in the Adrenalin software then it will boost the GPU performance quite a bit. "SAM" stands for Smart Access Memory. It only works with a AMD GPU I believe it will really turn up your gaming experience to a new level. It will out perform the 7700X.
I have been building PCs for 30 years so if you have any questions please ask. Also if you like this build and decide to go with it please mark it as the Solution.
https://pcpartpicker.com/list/xDrZtn
CPU: AMD Ryzen 7 5800X3D 3.4 GHz 8-Core Processor  ($318.02 @ Amazon)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  ($50.90 @ Amazon)
Motherboard: ASRock B550 Taichi ATX AM4 Motherboard  ($189.99 @ Newegg)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  ($104.99 @ Newegg)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($57.95 @ Amazon)
Video Card: ASRock Phantom Gaming D OC Radeon RX 6750 XT 12 GB Video Card  ($389.99 @ Newegg)
Case: Thermaltake S200 TG ARGB ATX Mid Tower Case  ($64.99 @ Newegg)
Power Supply: Thermaltake Toughpower GF3 TT Premium 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($139.99 @ Amazon)
Case Fan: Thermaltake Pure Plus RGB TT Premium Edition 56.45 CFM 120 mm Fans 3-Pack  ($39.99 @ Amazon)
Total: $1483.66
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
https://linustechtips.com/topic/1508543-first-pc-build/#findComment-15952399
Here is an Intel build if you wanted to go Team Blue. I'm not sure why you are not sure about the Thermalright Phantom Spirit or Peerless Assassin? They perform much better than the Be Quiet! Air and some of the Noctua Air Coolers. Thermalright is the "KING" of the Air Coolers right now. It has tons of 5 Star Reviews and even endorsed by top Tech-Tubers like Linus Himself, Hardware Unboxed, RobeyTech, Jays2Cents, Paul's Hardware, and many more.
https://pcpartpicker.com/list/LM86Y9
CPU: Intel Core i5-13400 2.5 GHz 10-Core Processor  ($199.99 @ Amazon)
Motherboard: Asus TUF GAMING B760M-PLUS WIFI D4 Micro ATX LGA1700 Motherboard  ($170.99 @ Amazon)
Video Card: Asus DUAL OC GeForce RTX 4070 12 GB Video Card  ($599.99 @ Amazon)
Case: Montech X3 Mesh ATX Mid Tower Case  ($59.99 @ Newegg Sellers)
Total: $1511.64
https://linustechtips.com/topic/1508543-first-pc-build/#findComment-15952421
Total: $1511.64
Thanks for the suggestions! I probably should have been more specific, I wasn't sure if the cooler would match the case lol. I know with this tier of CPU most coolers would do fine so I kinda wanted one that matched the black case and it is hard to tell the color of the cooler from the pictures.
https://linustechtips.com/topic/1508543-first-pc-build/#findComment-15953020
Total: $1483.66
Thanks for the suggestions! I'll probably end up going with this. How viable is buying second-hand with some of these parts? I have no problem with doing that. Also, how much benefit would I get from having a small boot SSD with my windows install? I remember getting suggested that a few years ago and I wonder if it is true. Thanks!
https://linustechtips.com/topic/1508543-first-pc-build/#findComment-15953024
Well the 5800X3D is fairly new and it only came out a few months ago. I really wouldn't get anything on this list second hand specifically the M.2 drives as they have a limited number of write times and you don't know how hard they were hit before you got it, the rest is a really big maybe, everything is so close to being new you would probably run into people selling them close to retail prices or over retail. The resell market is horrible and almost not worth it because of the prices, it's just as cost effective to buy brand new. At least you would get a warranty for new items.
As far as the Boot drives, I always try to go for a small boot drive separate from the larger files like game installs and media back up. Think about it, how long does it take to install Windows... 10 minutes at most these days if you use a USB 3.0 flash drive. Think about how long it takes to download a game and install it, a few hours per game maybe longer maybe less depending on download speeds and system speeds. If your OS ever gets corrupted it's just less of a hassle to have them separate drives plus they are so cheap these days it almost makes less sense not to have more than 1 drive.
https://linustechtips.com/topic/1508543-first-pc-build/#findComment-15953042
Completely agree with the boot drives, but man am i happy i have good internet. I don't usually think of this when building PCs because here 1Gbps symmetrical fiber optic connection is less than €25/month (falls down to under €20 if you combine it with your mobile and TV plan) so basically everybody has it.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
https://linustechtips.com/topic/1508543-first-pc-build/#findComment-15953480
