what games? might need a repaste or just trying to climb over its limits
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
https://linustechtips.com/topic/1508495-gpu-running-hot/#findComment-15951676
Old dry thermal paste
Dusty cooler
Poor airflow in case
Overclocked too far
Fan profile borked
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1508495-gpu-running-hot/#findComment-15951683
Dusty cooler
Overclocked too far
Fan profile borked
everything else is not an issue. but the old thermal paste can be an issue, since i purchased this in 2019.
https://linustechtips.com/topic/1508495-gpu-running-hot/#findComment-15951726
so my monitor turns on and Off due to some reason, im guessing its over heating.
added more details in anotherpost
can replicate issue with halo 2 Aniversary
https://linustechtips.com/topic/1508495-gpu-running-hot/#findComment-15951750
can you make a video?
Setup:
https://linustechtips.com/topic/1508495-gpu-running-hot/#findComment-15951772
9 minutes ago, RAGNES7 said:
What should the Video comprise of
monitor issue
Setup:
https://linustechtips.com/topic/1508495-gpu-running-hot/#findComment-15951821
