Hello, so I'm trying to upgrade my 120 gb ssd to a 1tb ssd that I have had for some time... after using mini tool 10 to copy the drive over windows is recognizing every different partition of windows on the new drive as its own individual drive. Is this a problem? How do I fix this? Can I just replace the drives physically right now and boot up? would it work? I'd like to get this done so I can replace the old one but as of now the new one is just connected through a usb 3 to sata adapter.
Thanks in advance for any help!image.png.3acc6c2ac5dc6e9cf81c7603caa99d16.png
(F drive is a hard drive I use for large file storage, everything but C is what the issue is. I thought it would all come in under one letter.
https://linustechtips.com/topic/1508478-partitioning-help/
For any issues I have in my PC, I found the best software for me is AOMEI Partition Assistant.  And I use the FREE version.  Check it out  and if it works for you, then great.  Well, if it doesn't work then at least we gave it a try.
https://www.diskpart.com/free-partition-manager.html
Take Care and Good Luck.
https://linustechtips.com/topic/1508478-partitioning-help/#findComment-15951623
