So I have really weird GPU temperature spike issue.
To start off GPU is EVGA GTX 1080 hybrid, I have dusted my pc and changed thermal paste for GPU.
Issue itself: During game play session temperature spikes from 60 degrees to 93 degrees and GPU inbuilt fan speed goes up to 100% roaring like jet.
When it happens: this problem happens randomly, what I mean by it is this issue may occur after 2 month or maybe after 2 weeks, but it is not stable issue (My best guess was that when I'm playing games at one point GPU needs to process big data and in that moment heat spikes but it never goes down)
After this kind of spike when I turn off the game temperature goes down at slow rate until 50 degrees, but never lower and GPU fan still roars like a beast even though it now works at 60% speed. To drop down temperature what works for me is unplugging GPU and waiting for 5min and then replugging. Then if I turn the same game up or for example FurMark and let it run for 1h or more no spikes anymore.
Also one strange case I'll hope that this info will help too, yesterday at night I had this spike again but it was late and unplugging and replugging was a hustle so I turned of PC and went to sleep, in the morning when I turned PC on again GPU fan was still roaring and on idle temperature was still 50 degrees, so I do unplugging/replugging again and it is fixed.
Edit : GPU has water cooling
https://linustechtips.com/topic/1507546-pc-gpu-temperature-spike-issue/
I've had blowerstyle GPUs in the past. On one of them, I kinda saw the same thing. Even though on the surface the graphics card looked fairly clean in terms of dust, inside the finstack of the blower cooler, bigger chunks of dust was building up. I remove the dust and issue was fixed. Since you have a 1080, you have had a long time for dust to build up inside the blower cooler. Maybe it's worth to have a look inside?
Edit:
Just found this: EVGA GTX 1080 FTW Hybrid Tear-Down | GamersNexus - Gaming PC Builds & Hardware Benchmarks
Looks like there's no real finstack but I guess dust still could have build up some places around chips and such but yeah my suggestion is maybe not the issue. Anyhow, I hope someone here can help.
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
I have opened it and removed  all dust but this still happens occasionally and only way to fix for me right now is to unplug/plug GPU then issue goes away
