1 minute ago, beans09 said:
what should i go for 7900xt or 4070ti
7900 xt, for sure
If your not ray tracing or if your not streaming (at least not on twitch) defo go for the 7900 xt
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1507242-pls-help/#findComment-15942050
7900XT all day every day. 4070Ti not even in the same class.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
https://linustechtips.com/topic/1507242-pls-help/#findComment-15942124
If you play a mix of games with RT enabled in some, they're actually identical in performance at 1440p. If you remove RT results, then the 7900XT is faster.
Here's the comparison chart from Hardware Unboxed:
https://linustechtips.com/topic/1507242-pls-help/#findComment-15942141
then again if your streaming (on twitch) currently it is better on the 4070 ti. But for pure gaming the 7900 xt is very good value
Total: £1040.95
https://linustechtips.com/topic/1507242-pls-help/#findComment-15942169
7900 XT will age better than the RTX 4070ti. RTX 4070ti is a pretty low quality cut of silicon comparably. The 7900 XT should see gains in performance through driver optimizations just like RDNA2 saw. Its RT performance is decent, but really you're not maxing out RT unless you've got an RTX 4090.
RT performance in my opinion is still not there yet to justify compromising for just like we saw with the RX 6000 / RTX 3000. You really need an RTX 4090 for a no compromise RT experience even at 1080p. Its only getting worse too with its new path tracing RT.
RX 7900 XT can at least toggle on lower settings to get some eye candy when you need it, but you're not getting the fullest experience with anything other than a RTX 4090.
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
https://linustechtips.com/topic/1507242-pls-help/#findComment-15942245
For pure gaming and occasional casual streaming, the RX7900XT. For raytracing in games, more serious streaming, and AI work, the RTX4070ti, but you'll have to live with less VRAM than the AMD card. Also, are they the same price where you're from?
PhiLia093
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor
CPU Cooler: Deepcool GAMMAXX 400 V2 64.5 CFM CPU Cooler
Motherboard: ASRock B450M Steel Legend Micro ATX AM4 Motherboard, BIOS P4.60
Memory: ADATA XPG 32GB GB (2 x 16GB) DDR4-3200 CL16 Memory
Storage: HP EX900 500 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive, PNY CS900 1 TB 2.5" Solid State Drive
Video Card: Colorful iGame RTX 4060 Ti 16GB
Power Supply: Cooler Master MWE Bronze V2 650 W 80+ Bronze Certified ATX Power Supply
Operating System: Microsoft Windows 11 Pro
Monitor: Acer QG240Y S3 24.0" 1920 x 1080 180Hz Monitor
Headphones: Superlux HD668B
IEMs: Moondrop Chu 2, Tangzu Wan'er Studio Edition
Speakers: Logitech Z313
Phone: Poco F6
https://linustechtips.com/topic/1507242-pls-help/#findComment-15942692
36 minutes ago, AnsVa said:
How about driver issues or coilwhine on 7900 XT?
If you want a detailed account from owners you should make a new post about it on this same subforum instead of hijacking a thread especially when theyre already getting pretty old.
You can start posting by clicking to the corner over here. Welcome to the forum.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1507242-pls-help/#findComment-15942757
