What type of VRAM is best for 16k workstation PC???
Solved by 8tg,
Faster vram will help with video editing more than higher quantities of vram would. 4k editing with gpu acceleration will use a lot of vram but would cap out way, way before hitting 24gb. Faster vram would be beneficial.
Now this also all depends on the gpus in question. If it was a matter of two otherwise identical gpus but with different vram setups, faster > more. But if you’re comparing different gpus there’s other factors to consider.
Featured Topics
idk_what.iam.doing ·
Posted in New Builds and Planning3 -
8
RevGAM ·
Posted in Member Reviews0 -
12
1
6
1
10
ColossusRev ·
Posted in New Builds and Planning2
play_circle_filled
Latest From GameLinked:
Are you excited for Doom: The Dark Ages? - Gamers 2 Gamers
