FPS issues
Solved by QuantumSingularity,
5 hours ago, Skillinky said:Okay, just to clarify I don't need to update my BIOS or I do?
And with the fps, this is just an example, on Fortnite on recommended settings my fps bounces from 100 to 40sh.
Thank you though
Although it's good to be on the latest stable version of the BIOS, you don't need to update it if everything is running stable. As for the FPS, it's normal. Just look any video on YT and every time High settings is used in Fortnite with the 3060, the FPS is from 40 to 110. Either reduce the setting to medium/low or get a better GPU.
