pair for overclocking
Go to solution Solved by bezza...,
yup perfectly fine for some basic overclocking 🙂
25 minutes ago, GOATWD said:
is this a ok amd based overcloking set up https://uk.pcpartpicker.com/list/yqqYMb
I would actually do some undervolting as it gives better performance for less or equal power
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1506375-pair-for-overclocking/#findComment-15935264
1 minute ago, Dreckssackblase said:
I'd consider going for 3600MT RAM speeds as ryzen chips do like quick RAM.
Besides that it's a really solid System.
so go for a bit of a speed up ok it just wasnt the mobo qvl list witch is why i went slower should it be ok to go with faster unsuported ram
https://linustechtips.com/topic/1506375-pair-for-overclocking/#findComment-15935265
What kind of overclocking will you be doing?
Theres cpu ram and gpu overclocking and i know for certain that generic 3200 set is not gonna be ideal for overclocking unless you get lucky and get some d9xpf (16gbit rev b) but you wanna be absolutely certain as to what ic you are gettin
also asus boards may have issues getting over 4600 ddr4 but that seems to be more of a random chance kinda thing, youd be better off with a steel legend/pg velocita since those have postcodes which are very helpful for general troubleshooting and overcloxking
And what will the system be used for aside from overclocking? because that does not look like an overclocking set cause if the only use was oc you wouldnt be looking at some crappy mid tier asus board and more like a b550 unify x or b550 aorus master
https://linustechtips.com/topic/1506375-pair-for-overclocking/#findComment-15935266
this was just someign i can overclock a bit then game on rlly  mainly cpu and gpu
https://linustechtips.com/topic/1506375-pair-for-overclocking/#findComment-15935271
3 minutes ago, GOATWD said:
how dose undervolting make it better and dose it maker hotter ?
no it doesn't make it hotter and it increases the boosts
Total: £1040.95
https://linustechtips.com/topic/1506375-pair-for-overclocking/#findComment-15935294
Btw you post a buncha build threads so im curious if you are just asking on behalf of your friends or something cause if its for a friend you should ask them about ocing and if theyre a diehard like me or just a casual that wants abit of extra performance
https://uk.pcpartpicker.com/list/qgQjwc
7700 + 6900xt + 32gb 6000c30
7700 will satisfy your cpu ocing more than a 5700x since instead of a mere 4.8 allcore you can do 5.4-5.5 on the 7700
As for the cooler if its priced >50$ get the ft120 instead, literally just a peerless assassin but diff name
Rams already fast enough out of the box so you wont have to worry about that, you can overclock em later for when you drop in a new cpu
Aside from that just a bunch of cost cutting measures (cheaper case, single 2tb cause high speed gen4 is pointless for non r/w heavy stuff, cheaper psu cause corsair is overpriced and specsheets dont matter)
As for monitor i do not have a suggestion cause i am not a peripherals guy and i would opt to just buy whatever 1440p 144/165hz used monitor i can get my hands on since i can find those locally at around 200-250$ used
https://linustechtips.com/topic/1506375-pair-for-overclocking/#findComment-15935297
well this is for me the others are for freinds but it wil be ligjht oc just for fun rlly and thx for the advice
i wont be able to go am5 as its a lot more expenive for now
https://linustechtips.com/topic/1506375-pair-for-overclocking/#findComment-15935299
I literally gave you a pcpp with am5 for the same price as that overpriced am4
Just go am5 even if that means dropping down to a 7600 or buying a used psu/case rather than being stuck on a dead end am4 platform
https://linustechtips.com/topic/1506375-pair-for-overclocking/#findComment-15935346
