Posted May 8, 2023 Budget (including currency): Country: Games, programs or workloads that it will be used for: Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Link to comment https://linustechtips.com/topic/1505761-parts/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 8, 2023 Just now, rust_naked1 said: Budget (including currency): Country: Games, programs or workloads that it will be used for: Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): depends what your using it for, if its gaming then 16 gigs is fine, and storage is up to you, if its the same price I would get the 3060 ti and for OS it doesn't really matter (but I wouldn't go with windows 1 lmao) Message me on discord (bread8669) for more help Quote me if you want me to get notified Current parts list: PCPartPicker Part List CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor (Purchased For £175.00) CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler (Purchased For £0.00) Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard (Purchased For £144.99) Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (Purchased For £89.99) Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (Purchased For £0.00) Storage: Kingston A400 960 GB 2.5" Solid State Drive (Purchased For £0.00) Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card (Purchased For £448.99) Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case (Purchased For £82.98) Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply (Purchased For £99.00) Total: £1040.95 Damn this space can fit a 5090 (just kidding, it needs more) Link to comment https://linustechtips.com/topic/1505761-parts/#findComment-15930517 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 8, 2023 3 hours ago, rust_naked1 said: Budget (including currency): Country: Games, programs or workloads that it will be used for: Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Why poll? Id prefer you writing this form down, im confused on what you wanna accomplish and your performance target, as @filpo may share implicitly. Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights Link to comment https://linustechtips.com/topic/1505761-parts/#findComment-15930839 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 9, 2023 Author i understand you thanks nd i didn't mean windows 1 lol Link to comment https://linustechtips.com/topic/1505761-parts/#findComment-15931649 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
