need some help for my first build, any changes or recommendations?
Budget:  1730 USD
Country: USA
Games, programs or workloads that it will be used for: higher end gaming like cyber punk and high graphic games. (1080p for now but want to run 1440p)
Build:
- NZXT H5 Flow Compact ATX 95$
- ARCTIC Liquid Freezer II 240 90$
- 2 arctic p14 pwm pst case fans (140mm) 24$ (12x2)
- Gigabyte z690 Aorus elite ax DDR4 197$
- EVGA SuperNOVA 850 G6, 80
Plus Gold 850W 160$
- Corsair Vengeance LPX 16GB (2
X 8GB) DDR4 3200 38$
- XFX Speedster MERC319 RX
6950XT 632$
- Intel Core i7-12700KF 289$
- WD_BLACK 1TB SN850X NVMe 90$
Tax: 97$
Total: 1711
https://linustechtips.com/topic/1505720-first-pc-planning-help/
there is no point in getting a liquid cooler get a NHD15
get a ddr5 model of the same thing
Plus Gold 850W 160$
you are overpaying for that get a 750e for like 120 ish
any ddr5 32gb
6950XT 632$
get something like this used and you might have the budget to go AM5
same thing as above
get a NV2 for half that
I hit 700W on an i5 with a NHD15
Also I'm 14 so please just confirm anything I say with someone more experienced
https://linustechtips.com/topic/1505720-first-pc-planning-help/#findComment-15930228
Is a 750w really gonna be enough? I’d rather have a 850 atleast.
14 minutes ago, Bob__ said:
Problem is that ddr5 ram is like double the price. So It will be like a 80$ bumb
https://linustechtips.com/topic/1505720-first-pc-planning-help/#findComment-15930252
a good 750 should be enough though you can get a 850 with how much is left in the budget
https://linustechtips.com/topic/1505720-first-pc-planning-help/#findComment-15930255
I sent you a system
https://linustechtips.com/topic/1505720-first-pc-planning-help/#findComment-15930257
PCPartPicker Part List
CPU: Intel Core i5-13600K 3.5 GHz 14-Core Processor  ($315.99 @ Amazon)
CPU Cooler: Deepcool AK620 ZERO DARK 68.99 CFM CPU Cooler  ($69.98 @ Amazon)
Motherboard: MSI PRO Z790-P WIFI ATX LGA1700 Motherboard  ($199.99 @ Newegg)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  ($99.99 @ Amazon)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($59.99 @ Amazon)
Video Card: PowerColor Red Devil OC Radeon RX 6950 XT 16 GB Video Card  ($629.99 @ Amazon)
Case: NZXT H5 Flow ATX Mid Tower Case  ($94.99 @ Amazon)
Power Supply: Phanteks AMP v2 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($169.99 @ Amazon)
Total: $1640.91
Generated by PCPartPicker 2023-05-08 12:14 EDT-0400
https://linustechtips.com/topic/1505720-first-pc-planning-help/#findComment-15930306
Total: $1640.91
the system I made has a MB that could be used in future years as well. It also has more SSD space and a more powerful GPU.
https://linustechtips.com/topic/1505720-first-pc-planning-help/#findComment-15930316
That's nice. The motherboard I included will also last for years. 🙂
The motherboard I suggested is on the memory kit QVL. It is also a bit faster.
I don't support products with which the manufacturer plays reviewer games. The only time I would suggest an NV2 drive is when the budget simply doesn't support anything else.
https://linustechtips.com/topic/1505720-first-pc-planning-help/#findComment-15930370
1 hour ago, Bob__ said:
I meant it can be upgraded
I knew what you meant. I'm just sick an tired of that red herring. I put the argument in the same class as "future proofing".
If one examines the history of recent AMD socket longevity, it turns out that in most cases new chipsets were introduced with new AM4 CPU.
I also wonder why anyone would willingly pair 2nd or 3rd gen DDR5 memory controller with a 1st gen motherboard.
https://linustechtips.com/topic/1505720-first-pc-planning-help/#findComment-15930598
3 hours ago, Bob__ said:
better system for less https://pcpartpicker.com/list/ZYkMLs
This is a WAYYYY better list OP, I'd go for this one with maybe a few minor changes below.
PCPartPicker Part List: https://pcpartpicker.com/list/QtdkVw
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  ($339.00 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($42.90 @ Amazon)
Motherboard: Gigabyte B650 AORUS ELITE AX ATX AM5 Motherboard  ($219.99 @ Amazon)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-5600 CL28 Memory  ($109.99 @ Amazon)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($122.99 @ Adorama)
Video Card: XFX Speedster MERC 310 Black Edition Radeon RX 7900 XT 20 GB Video Card  ($790.74 @ Amazon)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case  ($99.99 @ Newegg Sellers)
Power Supply: MSI MPG A750G PCIE5 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Newegg)
Total: $1835.59
Generated by PCPartPicker 2023-05-08 15:08 EDT-0400
I prefer the Lancool 216 VASTLY over the 4000d. At this price point you should be getting an ATX 3.0 PSU, so I changed that, and I'd go for 2tb of storage with how cheap it has gotten.
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
https://linustechtips.com/topic/1505720-first-pc-planning-help/#findComment-15930615
