5 hours ago, Mafi24 said:
Does it got solved now?
I guess you dont get the part that the reason of it being undetected is the fact that its because of Glorious software completely removing compatibility with it. No its not and it wont be. Also, whats your budget? Glorious QC is only getting worse week by week and there are many mouse brands now offering the same Zowie EC cloned shapes at same price or lower, with sometimes better QC and reliability either way.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
On 5/6/2023 at 4:38 PM, Mafi24 said:
In this video ( 8:08 ) Linus is talking about software issues with the Model O. Does it got solved now? If not, what will I miss without it? I'm curious because I would like to buy one.
just get a logitech g305 or a razer deathadder
you dont need an aio for anything but i9 cpus or heavy oc jobs just get an nh-d15 or peerless assassin
MARK THE SOLUTION AS SOLUTION
i am 14 so i may be wrong sometimes
@Bob__ is a w
  • 2 weeks later...
Luclely I'm not in love with Glorious so I will choose another mouse. The one You recommended is looking good, but it's only in black (at least the wired one and I want wirelless one), but thanks for the help. Sorry for the late reply, My dumb head forgot that I posted here😅
On 5/7/2023 at 5:42 PM, GarekM said:
It's still happening for me, zero support from Glorious. I was having so many problems that I uninstalled the Glorious software and bought a G502. (I had a Model D Wireless.)
I don't like the shape of the G502, but I might get a G Pro X Superlight. Thanks for the help! Again, sorry for the late reply.
