So i just bought this new RAM, DDR3 SK Hynix 8GB 12800, and it doesnt work on my Motherboard ( H18 with i3 4150 ).
It just wont display on single/dual channel ( with my old 4gb RAM {10600} )
And then i asked for a change for the ram. Giving all the informations and proofs, only just to be replied with the seller saying that my motherboard is a built up motherboard, doesn't support a "black coloured" RAM
Screenshot_2023-05-05-23-41-24-97_680d03679600f7af0b4c700c6b270fe7.thumb.jpg.34e0714031e1577df04dbe6ef8dd35d4.jpgScreenshot_2023-05-05-23-42-10-16_680d03679600f7af0b4c700c6b270fe7.thumb.jpg.cae7bb4f04822582e86da7e72627c202.jpgScreenshot_2023-05-05-23-43-04-30_680d03679600f7af0b4c700c6b270fe7.thumb.jpg.5b3354ce0220f7bd63a5802c1c85b96d.jpg
Sorry if the translations messed up. Im too lazy to fix all of the incorrect texts
Just an Ordinary Senior High-Schooler.
Please correct me if Im wrong when posting on someone's forum, that would really help me out. 👌
https://linustechtips.com/topic/1505092-i-need-help/
On 5/6/2023 at 12:43 PM, SorryClaire said:
christ id rather take the Indonesian version. Can you private message me that instead?
nah case closed, its a ram faulty, i have two of them, one stick do work really well, and the other dont, why i made this post is because my other ram hasn't arrived yet, nevertheless, i contacted the shop and they will to return the faulty ram, but im still curious tho, do built up motherboards are picky when choosing ram?
https://linustechtips.com/topic/1505092-i-need-help/#findComment-15931208
I mean they are in some cases, either due to vendor lockout or mismatched profile. If your prebuilt has a memory QVL, referring to that would save you a lot of time.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1505092-i-need-help/#findComment-15931244
okay, thanks for replying.
https://linustechtips.com/topic/1505092-i-need-help/#findComment-15931458
