[SQL/Python] Writing SQL Statement for specific use-case
Go to solution Solved by Zalosath,
A bit complex but I got it working:
SELECT p.*
FROM posts p
LEFT JOIN (
  SELECT parent_post_id, MAX(timestamp) AS max_timestamp
  FROM posts
  WHERE parent_post_id IS NOT NULL
  GROUP BY parent_post_id
) p2 ON p.post_id = p2.parent_post_id
WHERE p.parent_post_id IS NULL
AND forum_id=1
ORDER BY p2.max_timestamp DESC
Hi,
I'm writing a forum style web page for a project and I'm having a little trouble writing an SQL statement for the below use-case:
I have a "Posts" table that stores all posts, including the original post and any replies, this structure is as follows (left some irrelevant information out):
post_id # the ID of this post
forum_id # the ID of the forum this post was made in
parent_post_id # the ID of the post it refers to, NULL if it's an original post
timestamp # when the post was posted
When I fetch the posts to display on a forum page, I want to order them by most recent activity, but I can't figure out how to do that.
I've got this:
cursor.execute(f"SELECT post_id, post_title, post_author, timestamp FROM posts WHERE forum_id='{forum_id}' AND parent_post_id IS NULL ORDER BY timestamp ASC")
Which only considers the original post, so basically I need a way to select only original posts but that are ordered by the most recent post in the posts table for that post id.
Any ideas?
Main PC [ CPU AMD Ryzen 9 7900X3D with H150i ELITE CAPPELIX  GPU Nvidia 3090 FE  MBD ASUS ROG STRIX X670E-A  RAM Corsair Dominator Platinum 64GB@5600MHz  PSU HX1000i  Case Lian Li PC-O11 Dynamic  Monitor LG UltraGear 1440p 32" Nano IPS@180Hz  Keyboard Keychron Q6 with Kailh Box Switch Jade  Mouse Logitech G Pro Superlight  Microphone Shure SM7B with Cloudlifter & GoXLR ]
Server [ CPU AMD Ryzen 5 5600G  GPU Intel ARC A380  RAM Corsair VEGEANCE LPX 64GB  Storage 16TB EXOS ]
Phone [ Google Pixel 8 Pro, 256GB, Snow ]
SELECT p.*
FROM posts p
LEFT JOIN (
  FROM posts
AND forum_id=1
