Need help picking between Ryzen and Intel
Solved by Leandro Fernandes,
Considering you won't have much to spare for a GPU with that budget, either option will yield around the same fps in gaming seeing as you'll probably be GPU bound. Me personally, I would go with the Ryzen chip just because it's "unlocked" and I can have fun with it.
You should also consider going for used parts like @NO101 recommended. If you are comfortable trusting second hand sellers, you'll get higher performance for the same price.
