What's the system being used for?
What psu and hdd do you have?
Is a copy of Windows or any peripherals needed?
https://linustechtips.com/topic/150436-help-on-picking-parts/#findComment-2010167
With that budget, if you want you could go for an APU build and when you have more money add a nice graphics card and more ram if you want:
CPU:  AMD A10-7700K 3.4GHz Quad-Core Processor  ($174.98 @ Newegg Canada)
Motherboard:  MSI A88XM-E35 Micro ATX FM2+ Motherboard  ($71.99 @ Canada Computers)
Memory:  Kingston Blu 4GB (1 x 4GB) DDR3-1600 Memory  ($39.99 @ Memory Express)
Case:  Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($39.99 @ Memory Express)
Total: $326.95
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-05-10 16:52 EDT-0400)
Main PC:
ASUS F1A55-M LX, AMD A6-3500, (2x2)gb Kingston HyperX Blu DDR3 1600mhz, Seagate Barracuda 500gb 7200rpm,
 Corsair CX430M, Cooler Master Elite 343, Windows 8.1 Pro 64-bit
Netbook:
Lenovo Ideapad S10-2, Intel Atom N280, (1x1)gb DDR2 667mhz, WD Scorpio Blue 250gb 5400rpm, Zorin OS 9 Lite
https://linustechtips.com/topic/150436-help-on-picking-parts/#findComment-2010185
I have the CX430M and 2  of Seagate 500TB
and it s being used for mostly gaming
and no windows or peripherals
Also if it matters, i have a gt 610 and may upgrade to a gtx 750 ti later on
https://linustechtips.com/topic/150436-help-on-picking-parts/#findComment-2010220
Total: $326.95
What is the difference between a10-7700k and a10-5800k... The clock speed is higher but it is cheaper. Can you tell me why?
https://linustechtips.com/topic/150436-help-on-picking-parts/#findComment-2010228
the 5800k is an older cpu, and it has a worse igpu.
Main PC:
Netbook:
https://linustechtips.com/topic/150436-help-on-picking-parts/#findComment-2010254
OP for your graphics card upgrade please consider the r7 265 or GTX 660 instead of the 750ti, both these card outperform the 750ti by about 15 to 20% and cost about the same...you pay a premium for the low power consumption of the 750ti
but since you have a descent PSU already you should go with the r7 265...
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/150436-help-on-picking-parts/#findComment-2010265
I will consider it
https://linustechtips.com/topic/150436-help-on-picking-parts/#findComment-2010275
What kind of games are you planning to play?
https://linustechtips.com/topic/150436-help-on-picking-parts/#findComment-2010279
in how long do you think you will be ready for a GPU? because it would make more sence to get a better CPU and use the GT610 that you have until you can get a good GPU...
The APU will provide better graphics until you get a GPU but you are sacrifising on CPU processing power and you are spending money for the IGP that you will no longer use when you get
a graphics card...
https://linustechtips.com/topic/150436-help-on-picking-parts/#findComment-2010310
a graphics card...
About a month or so. If you're picking the parts or something, can you please make 2 different completes: One with the apu and one with a cpu + 610 (that will be upgraded)
https://linustechtips.com/topic/150436-help-on-picking-parts/#findComment-2010324
Yes the FX-6300 is better in games that use more than 2 threads, some older games that use only 1 or 2 heavy threads run better on the core i3 though, but for future games and modern games the FX-6300 is a much better CPU overall...
now back to you, here...if you're going to have to wait for a month, get something like this and use your GT610 until you can afford a radeon r7 265, this CPU is better than an APU and cost less...also down the road you might want to add
another 4gb of RAM for dual channel performance and also more capacity because some games use more than 4gb, but for now you're okay..:
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  AMD Athlon X4 760K 3.8GHz Quad-Core Processor  ($95.98 @ Amazon Canada)
Motherboard:  MSI A78M-E45 Micro ATX FM2+ Motherboard  ($69.69 @ DirectCanada)
Total: $205.66
(Generated by PCPartPicker 2014-05-10 17:21 EDT-0400)
https://linustechtips.com/topic/150436-help-on-picking-parts/#findComment-2010338
Im planning to play DayZ, BF4 (when i upgrade the gpu), cod ghost, bioshock, nba 2k14.
This is what you could currently get: http://ca.pcpartpicker.com/p/3HxW6
https://linustechtips.com/topic/150436-help-on-picking-parts/#findComment-2010357
Total: $205.66
Which one is better? The fx-6300 or x4 760k because if the fx is better, i can just get that
https://linustechtips.com/topic/150436-help-on-picking-parts/#findComment-2010368
yes the fx is much better if it fit in your budget then go with that and an am3+ motherboard 970 chipset
https://linustechtips.com/topic/150436-help-on-picking-parts/#findComment-2010409
here, if you could afford something like that, find a cheap case and later add an r7 265, you would have a very good gaming machine:
CPU:  AMD FX-6300 3.5GHz 6-Core Processor  ($119.99 @ NCIX)
Motherboard:  ASRock 970 Pro3 R2.0 ATX AM3+ Motherboard  ($73.00 @ Vuugo)
Memory:  Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($75.77 @ DirectCanada)
Total: $268.76
(Generated by PCPartPicker 2014-05-10 17:37 EDT-0400)
https://linustechtips.com/topic/150436-help-on-picking-parts/#findComment-2010432
