Budget (including currency): $1500-1800 USD
Country: USA
Games, programs or workloads that it will be used for: Flight and Racing Simulator Games, Adobe Photoshop and Lightroom, Possibly some AAA games (new to games at the moment)
This is my current build that was picked out by a friend. Some parts are already purchased/owned. I am looking at a resolution of 1440p or very high 1080p should work fine for me.
https://pcpartpicker.com/list/FcMVMb (Note: parts that are already purchased are the 2 SSDs, Corsair PC case, and RAM - though the RAM can still be returned)
Thanks in advance for the advice!
https://linustechtips.com/topic/1504287-first-pc-build-help/
Country: USA
Do you live by a Microcenter?  If so, they have some deals going on.
You can get a 6950XT for $619 as well...
ASRock Phantom Gaming Radeon RX 6950 XT Video Card RX6950XT PG 16GO - Newegg.com
I'd tweak a few things, but it's the right idea.  I'd get more SSD, better cooler (unleashes the 7700x a bit more), and probably a little tighter RAM timings if I had to be picky.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1504287-first-pc-build-help/#findComment-15919448
10 minutes ago, N0l1ge said:
Hi,
which parts are already bought?
It would really help to know that:o
best regards
Hi, The parts that are bought are the SSDs (SATA and NVMe) and the Corsair Case. I just recently purchased the RAM ($99.99), but I can still return it.
https://linustechtips.com/topic/1504287-first-pc-build-help/#findComment-15919451
Unfortunately, I do not have a Microcenter close by.
For the cooler, I know there's the Deepcool AK620. Would that be sufficient or are there any recommendations?
https://linustechtips.com/topic/1504287-first-pc-build-help/#findComment-15919455
The AK620 is what I would go with for air at that price/performance.  I went 360mm AIO and still hit 90c+ before PBO undervolting.  They run hot, or rather they run and run until temp stops them.  Keeping the temps down lets them run faster.
The 7700x + 6950XT is a fantastic combo, especially for that $620 price on the 6950XT.  Will let you run high fps 1440p.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1504287-first-pc-build-help/#findComment-15919488
Country: USA
Your choice of RAM is going to hurt you seeing how it's high latency RE CL40.
RAM
https://pcpartpicker.com/product/x4VmP6/gskill-ripjaws-s5-32-gb-2-x-16-gb-ddr5-6000-cl30-memory-f5-6000j3040f16gx2-rs5k
CPU
https://pcpartpicker.com/product/dXmmP6/amd-ryzen-7-7700-36-ghz-8-core-processor-100-100000592box
PSU
https://pcpartpicker.com/product/8z7p99/super-flower-leadex-iii-gold-850-w-80-gold-certified-fully-modular-atx-power-supply-sf-850f14hg
https://linustechtips.com/topic/1504287-first-pc-build-help/#findComment-15919549
45 minutes ago, Why_Me said:
I looked back at my original purchase from Amazon. This is the RAM I bought (https://www.amazon.com/dp/B0B771BL4S?ref=ppx_yo2ov_dt_b_product_details&th=1) which I believe is CL 36. I'm unfamiliar with those terms, could you give a quick TLDR about them?
Regarding the CPU why do you recommend the 7700 instead of the 7700x?
As for the PSU, aside from price, is there any benefit between the super flower PSU you suggested?
https://linustechtips.com/topic/1504287-first-pc-build-help/#findComment-15919633
CL36 is better than CL40 and CL30 is better than both.
The 7700 runs cooler while netting similar results.
The PSU is all about price as in saving a few bucks.
https://linustechtips.com/topic/1504287-first-pc-build-help/#findComment-15919641
To expand:
  1. AMD CPU architecture as it goes right now heavily favors access time of the RAM, and this is commonly expressed within CAS Latency which is the RAM timing. This means that lower the CL number, generally the better. But of course we havent addressed the nerdy stuff that would make that statement sometimes better like subtimings.
  2. 7700 non X variants cuts the Extended Frequency Range instruction which unlocks all of Ryzen power budget at boost till the cooler or motherboard is overwhelmed. This is amazing for stock operation but they legitimately run super hot as a result. And all that for performance and temperatures that are inferior to hand tuning it.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1504287-first-pc-build-help/#findComment-15919687
15 minutes ago, SorryClaire said:
To expand:
I stopped watching when he compared the i5 13600 to the i5 13600K.  He's either clueless or being disingenuous because anyone with a clue knows the 13600 is built upon the 12 gen Alder Lake platform.
https://www.intel.com/content/www/us/en/products/sku/230574/intel-core-i513600-processor-24m-cache-up-to-5-00-ghz/specifications.html
Memory Types: Up to DDR5 4800 MT/s
https://www.intel.com/content/www/us/en/products/sku/230493/intel-core-i513600k-processor-24m-cache-up-to-5-10-ghz/specifications.html
Memory Types: Up to DDR5 5600 MT/s
https://linustechtips.com/topic/1504287-first-pc-build-help/#findComment-15919708
47 minutes ago, SorryClaire said:
To expand:
So bringing back what was being said in this video. If I choose the 7700, it comes with a stock cooler already. Do you think it's necessary to buy a separate one or use the stock?
https://linustechtips.com/topic/1504287-first-pc-build-help/#findComment-15919750
What? It is Raptor Lake, the rated speed in ARK is the limit for non XMP operation because that is overclocking, and K sku does have higher stock ram speed.
https://linustechtips.com/topic/1504287-first-pc-build-help/#findComment-15919767
The 13600, 13500 and 13400 / 13400F are all built upon Alder Lake tech hence the reason those cpu's nativily support DDR5 4800 and not DDR5 5600. All intel did was add a few e-cores along with some extra cache to those cpu's and rebadged them as Raptor Lake.
https://linustechtips.com/topic/1504287-first-pc-build-help/#findComment-15919769
If I decide to switch the cpu to 7700, would the 6950xt still be a good choice?
https://linustechtips.com/topic/1504287-first-pc-build-help/#findComment-15919926
Yes, since you're going 1440p.   Especially since you were going to spend $600 on a GPU, get the best one you can.  I have a 7700x and a 6900xt, for comparison.
The 7700 will perform almost like the 7700x, so that's a wash.  I'd pay the extra $25 for the x but that is your call, I don't have experience with the non-x version and I know the 7700x is a very solid performer.
I paid $629 for my 6900xt, I would gladly pay $619 for the 6950xt.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1504287-first-pc-build-help/#findComment-15920514
