Logical Volume Management in Linux?
Go to solution Solved by Brief-Wishbone,
I've got it. I just needed to add a new disk using vmware workstation pro. And continue that article on linustechi.com
For eg: this tutorial
I'm unable to continue from here.
>From the above output we can see that there is a physical volume (PV) named /dev/sda2 and the PV is a partition of the first disk drive. We can also see that there is a volume group (VG) named centos on this physical volume.
>Now we want to add another Hard Disk Drive to increase our volume group. The new HDD will be the second Disk Drive and the device location will be /dev/sdb. To find your newly added drive location, issue the following command.
I'm wondering what're the preriquisites to start a LVM tutorial.
Can you share a step by step guide to use set up LVM and test some cases?
It includes prerequisites as:
>Raw disk attached to Linux system
What does this mean? How do I do it in my system? I can't attach a totally new disk as I don't have money for that at the moment.
How do I do it?
https://linustechtips.com/topic/1504203-logical-volume-management-in-linux/
