Budget (including currency): 2500
Country: USA
Games, programs or workloads that it will be used for: CAD some gaming
Other details
Adding the files for both the parts and how I currently have the fans oriented. Unfortunately the top of the case only supports up to 280mm. So I used some of my old case fans from a build (ASUS Helios) that are 140mm, and 1 included 120mm case fan from this Corsair 4000 as exhausts.Wondering if my airflow would be sufficient for this build.
https://linustechtips.com/topic/1504102-fans-and-placement/
