Are there any indicators of a performance loss, like thermal throttling?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1504027-red-cpu-light/#findComment-15917209
21 minutes ago, Merkrow said:
Yeah but i have a dark rock pro 4 idk why am i getting this kinda of temps
It looks like the CPU is getting to some really high clocks despite the temps. A minor undervolt on the CPU might help keep things in check.
Also, does your case have good airflow? And keep in mind, cinebench is a pretty hardcore CPU bench test. Compared to something like gaming, it's not really representative of real world stress.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1504027-red-cpu-light/#findComment-15917255
My airflow is ehh not the best but not the worst i know i can do better there gaming performance is about 60 80 maxiumun like the absolute maxiumum
https://linustechtips.com/topic/1504027-red-cpu-light/#findComment-15917307
Yeah, if gaming is typically the most demanding thing that the PC is doing, then I wouldn't worry about it much
Primary PC:
PSU tier list
https://linustechtips.com/topic/1504027-red-cpu-light/#findComment-15917340
12 minutes ago, Merkrow said:
85 max heat while gaming is it bad or good not constant but max
not bad, especially as you said the case airflow is not great
Primary PC:
PSU tier list
https://linustechtips.com/topic/1504027-red-cpu-light/#findComment-15917730
I think temp is fine 205 W at 95C isn't bad... What is your ambient temperature mine is usually 189 w @ 80 C.. Deepcool assassin 3 cooler...
https://linustechtips.com/topic/1504027-red-cpu-light/#findComment-15917818
9 minutes ago, Merkrow said:
Around 20 C but underbenchmark it thermall throttles like crazy
Download powermax and run stress test and run hwinfo and report your max temperature... Use avx not sse and run it for almost 30 min... Use time indefinite and you can quit after 30 min
https://linustechtips.com/topic/1504027-red-cpu-light/#findComment-15922685
