CPU Overheating
Go to solution Solved by Bob__,
13 minutes ago, Craigger said:
I know there have been others with CPU Overheating problems but I haven't seen any post for this specifically. I have an i7 13700KF and idle temps are around 40 C I have a Be Quiet! Dark rock Pro 4 cooler and right as soon as I open games such as Valorant or Overwatch it instantly overheats and goes to 100 C. I've taken off the cooler cleaned off old thermal paste put new thermal paste on, tried messing with fan curves, checked for driver updates/ Windows Updates as well. even did a clean boot since I know Vanguard Anti cheat has caused problems for others in the past. I have out of ideas on what to try but I can't play certain games without it instantly going to 100 C. I built the PF in January and this just randomly started happening.
can I see your clocks at idle and when you open a game also yeah it is normally quite hot if you want it to run cooler you can undervolt. (turning down the voltage until the PC crashes and then go slightly higher)
https://linustechtips.com/topic/1503416-cpu-overheating/
Zen4 and pretty much every intel CPU past 9th gen aims to clock as high as possible without throttling. So, its not "overheating" its just running hot. If your computer isnt shutting down abruptly or clocking below its base clock, there is nothing wrong.
https://linustechtips.com/topic/1503416-cpu-overheating/#findComment-15912732
It was doing it when you built it, you just didn't notice or check.
As said above, working as intended.  There are ways to bring the heat or voltage limit down though in BIOS.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1503416-cpu-overheating/#findComment-15912740
I hit 700W on an i5 with a NHD15
Also I'm 14 so please just confirm anything I say with someone more experienced
https://linustechtips.com/topic/1503416-cpu-overheating/#findComment-15912743
I've been using NZXT Cam since getting the PC built. It's never reported a higher temp that 74 C till now.
https://linustechtips.com/topic/1503416-cpu-overheating/#findComment-15912806
Not home right this second. Will do later
https://linustechtips.com/topic/1503416-cpu-overheating/#findComment-15912812
7 minutes ago, spongebob123789 said:
DDU install stable drivers(not latest). Google search stable drivers for alm pc parts and roll back.
Would like to explain how uninstalling graphics card drivers using DDU would help OP with a CPU that is running hot?
https://linustechtips.com/topic/1503416-cpu-overheating/#findComment-15912857
1 minute ago, spongebob123789 said:
What I meant was for all parts not only the GPU. For CPU, motherboard, roll back I meant.
Do you have any clue about anything you are talking about? DDU literally stands for Display Driver Uninstaller. At best, it can uninstall audio drivers other than graphics card drivers. Updating or rolling back drivers will not help with a CPU that is running hot due to its boost behavior (which can be controlled in bios).
https://linustechtips.com/topic/1503416-cpu-overheating/#findComment-15912867
