Dear users of LTT Forum,
the following states my PC Specs:
- i5 9400f
- Galax RTX 2060
- 8x2 8gb DDR4
- Stock CPU Cooler (the push pins)
I assembled the PC on November 2020, just before the pc market in my country went bazinga. For the past 4 - 5 months, the CPU had been idling at 50 - 70C. My GPU also started becoming hot while loading games. So I replaced the thermal paste on both the CPU and GPU.
After that, the temps are still at 50 - 70C on my CPU and my GPU is much better while playing games.
The thing where I'm most concerned is my CPU as when I opened up Apex Legends, my CPU's stock cooler started going really fast and while checking the temps, it went all the way upto 90C! It was hovering over 80 - 85C at that time IN THE LOADING SCREEN! I honestly don't know what to do now and I barely have time to play games too, but when I do and this happens, it's just sad.
I did log from HWiNFO a few times after re-applying thermal paste for reference.
Help offered to this problem would be really beneficial! I shall be thankful to thy great!
24_04_23.CSV 25_04_2023.CSV
https://linustechtips.com/topic/1502882-temps-go-brr/
the stock cpu cooler are crap imo. even a cheap $20 cooler would be an upgrade.
why the temps gos up now i dont no.
https://linustechtips.com/topic/1502882-temps-go-brr/#findComment-15908194
- i5 9400f
- Galax RTX 2060
- 8x2 8gb DDR4
No one is going to open those attachments. Too risky.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1502882-temps-go-brr/#findComment-15908871
8 hours ago, bsod2528 said:
its a log file from hwinfo themselves
In that case, paste them in, please.
https://linustechtips.com/topic/1502882-temps-go-brr/#findComment-15910462
