Budget (including currency): $350-$400 USD
Country: USA
Other details:
I need help finding/suggestions for a kit to water custom loop water cool a Gigabyte Waterforce 3080 that i am being given. I don’t mind if I have to cool the cpu with the same loop (would prefer to, but don’t have to if it’s over budget). This is my first custom loop.
Below are the links to the card and the current set-up:
https://tinyurl.com/9wpyechr
https://pcpartpicker.com/list/CVkDK3
Thank you in advance for any help I receive.
https://linustechtips.com/topic/1502833-help-with-a-custom-loop/
Country: USA
Other details:
Not sure any such kit exists, but you can shop parts
Pump (a small DDC will do)
Tubing (say 2m), soft tubes (hard tubing is .. hard 😛 )
At least 6 fittings, or 8 if the looop includes the CPU
And a waterblock for the CPU
Beware seems the GPU block has aluminium so you need to AVOID any copper in your loop (else it will make some chemical reaction that will create dung clogging the block ..)
