Budget (including currency): 850 usd
Country: USA
Games, programs or workloads that it will be used for: Minecraft, Fortnite, Valorant, video transcoding, blender, uefn, unity, unreal engine
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): https://pcpartpicker.com/list/btPHXy this is my work in progress build. Also my dad works at intel so he get a discount on cpu's and i could get the i5 13600k for 170 usd.
https://linustechtips.com/topic/1502686-first-build/
Country: USA
seems good but i would change a few things: https://pcpartpicker.com/list/fWNF78
With the discount its just a bit over
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1502686-first-build/#findComment-15906681
https://pcpartpicker.com/list/kBb6C6
13600k + used 6700xt
for the case look on the used market, you really dont wanna spend more than 20$ on one at this budget if you wish to maximize your spec
Same thing for the psu, you can problably find used 700-850w gold units for 50$ or less, here in indo they go for 50$ ish, besides most of them still have years of life left since psus last 10-15 years (leaning towards 15 years)
https://linustechtips.com/topic/1502686-first-build/#findComment-15906765
Here's an updated list https://pcpartpicker.com/list/znZdBj im gonna keep the noctua fan and the 6650 xt just because i couldn't find a good used rx 6700 xt under $310 that didnt have a broken fan or something. I did find a good 850w psu for $50 full mod. also the case has 4 fans preinstalled.
https://linustechtips.com/topic/1502686-first-build/#findComment-15907215
