HDD Heat issue?
Go to solution Solved by bezza...,
should be fine just ignore it unless you notise anything else wrong with the hdd
I recently got a program (Disk Checkup) to check my 5 year old SSDs health, and it is reporting all is good with both my SSDs, however it is warning me my HDD is High Temp?  which according to HWInfo the drive is around 33°c and is not warm to the touch at all.
Is this just an HDD issue or should i be concerned?
https://linustechtips.com/topic/1502558-hdd-heat-issue/
Run crystaldiskinfo and post here a screenshot of that HDD smart ( all parameters), just to be safe.
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + Thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + PLX88024 PCIe switch (PCIE 4.0 x8 -> 4 x M.2 PCIe 4.0 x4) -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD : LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + flexiDOCK MB014SP-B + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aiyima A80 ( or Aune S6 Pro -> RCA ->  Aiyima A80 ) -> Polk S20e black -> Monoprice stand 16250
HEADPHONES : PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + Kensington VeriMark / PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Razer Wolverine V3 Tournament Edition 8K PC (B0F94C9C43) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox series x controller pc (1VA-00002) + Ravcore Javelin
NET :  Intel E810-XXVDA2 2 x 25GbE SFP28 (PCIE 4.0 x8) -> 2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3) -> Qnap TS-932X-2G + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB -> 2 x FTLX8571D3BCV-IT -> Noctua NF-P14s redux 1200 PWM -> QNAP TR-004
https://linustechtips.com/topic/1502558-hdd-heat-issue/#findComment-15905870
Max recorded temp is 57 C and that is a lot.
is the current temp from HWInfo the same as the CDI, it was 38C in CDI in time of the screenshot?
EXTERNAL
HDD/SSD :
https://linustechtips.com/topic/1502558-hdd-heat-issue/#findComment-15906227
as of right now Both are reading 39°c on that HDD. and within 0.5°c on the SSDs
https://linustechtips.com/topic/1502558-hdd-heat-issue/#findComment-15906289
maybe it was reading the worst temp so 57C, and alerting that there’s something wrong with cooling, and you need to look at it.
do you have an idea, when the HDD reached that 57C?
EXTERNAL
HDD/SSD :
https://linustechtips.com/topic/1502558-hdd-heat-issue/#findComment-15906324
Active running Theory, my case is to small to allow good airflow.
If i game on it my GPU gets quite hot as it becomes stall air quickly(the GPU just clears the Case side wall) so that would be my first thought.
I also had my case ona a Neg press by mistake so i have changed a few of the fans around to allow Push Pull properly.
the HDD also sits Under the PSU Shroud so that may be a factor as well.
https://linustechtips.com/topic/1502558-hdd-heat-issue/#findComment-15906417
does it have any direct airflow?
what pc case it is?
EXTERNAL
HDD/SSD :
https://linustechtips.com/topic/1502558-hdd-heat-issue/#findComment-15906435
what pc case it is?
Not directly, due to its location the PSU shroud blocks where i could put a Fan, I do have the Upper cover of the PSU shroud removed so the fans can push air on it.
the case is a Phanteks ECLIPSE P400(I think, Its a solid front panel with Tempered glass on the one side)
https://linustechtips.com/topic/1502558-hdd-heat-issue/#findComment-15906459
