i have no idea what to do, ive been through task manager nothing taking up resources but computer is just sluggish as hell.
CPU: AMD RYZEN 5 3400G @ 3.1 GHZ, RAM: Teamgroup elite 12gb DDR4 @3200mhz, MOBO: GA-A320M-S2H v1, GPU: Gigabyte Rtx 3060 OC 12 GB, CASE: Old Antec one i found, PSU: CV750 Corsair
https://linustechtips.com/topic/1502145-pc-running-like-crap/
this should be in troubleshooting section
regarding the statement, have u installed everything that you need to (graphics drivers, chipset drivers, bios) Also check your temps and power draw. Has this happened instantly or has this just come up recently and was working fine before?
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902525
all drivers are installed and cpu and gpu power and temps seem ok, it has been sluggish for a while but has just gotten progressively worse
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902536
would you mind installing cinebench r20, furmark and memtest86 so i can diagnose it a bit more (cinebench r20 tests cpu, furmark at 1080p max tests gpu and memtest86 tests ram)
Total: £1040.95
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902539
Check if boot drive is near full
Reinstall Windows
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902540
i was able to run cinebench and furmark
Furmark;
Avg FPS; 137
Points; 8208
Cinebench;
Points; 4248
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902555
Avg FPS; 137
thats around what i got with my 3060 so can't be that
Cinebench;
Points; 4248
was this r20? cuz a 3400g normally gets 2000 in that
if it was r23 or r15 then it makes more sense
Total: £1040.95
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902561
r23 sorry it was the one i had installed
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902567
oh ok, ye the 3400g on average gets about 4800 points in that so don't think thats the problem either. Has this been happening with games too?
Also i would take @PDifolco's advice if all else fails as it seems like the only way
Reinstall Windows
Total: £1040.95
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902571
yes it has. i have only really been playing microsoft flight sim and a couple days ago all of a sudden the cpu would continuously lag spike during gameplay
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902576
so it might be your power constraints from your mobo (i had this problem too with an old h510m a pro mobo and 10100f, @Tomberry will know what i'm talking about). Do you have msi afterburner and riva tuner installed? If not then install it so you can see the power draw of the cpu and gpu in game. Do you know how to configure msi afterburner like that?
Total: £1040.95
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902580
could i just use geoforce experience or hwinfo
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902583
hmm it could be. but looking at your specs in more deatail you are running a pretty low end cpu (pretty much all the ryzen apus excuding the 5600g and 5700g r not that good) and flight sim is a pretty cpu intensive game. also you are running 12 gigs of ram. check gpu and ram usage in the game. also did you check how full ur boot drive is. also what is the boot drive that you are currently using??
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902584
ye but they've had loads of weird problems in windows too tho. just windows isn't THAT cpu intensive. IMO i think its power contraints from the bad vrms
you could use hw info but that won't be available as an overlay in the game. geforce experience doesn't show cpu power draw. MSI Afterburner download: Afterburner (msi.com)
Total: £1040.95
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902586
the drive is a TS480GSSD220S, cpu and ram usage is pretty high but not pinned and when viewing the debug fps windows (part of msfs) it shows the main thread and coherentgtui where both lag spiking into 50ms each multiple times a second
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902587
the board they're using has pretty bare vrms and power delivery too as well as not having many of themimage.png.b128a0be1e8c6a205fb01feff6de9733.png
Total: £1040.95
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902588
i do have 2 moniters and msi afterburner has always been a pain for me
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902589
you got a cpu bottleneck then. RAM is fine if its like 1 gig below, but if the gpu isn't maxing with no frame rate cap on then its a cpu bottleneck. How much pwr is the cpu drawing btw?
Total: £1040.95
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902590
hmm i doubt it. that cpu does not use that  much power and ive had a pretty good experiene with low end amd mobos and better cpus then the 3500g
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902592
i do have the vrms modded with custom heatsinks
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902593
why's that? I love it
Total: £1040.95
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902594
65 watts on cpu
i do have a cap at 60fps though
https://linustechtips.com/topic/1502145-pc-running-like-crap/#findComment-15902595
