I asked so many people will it bottleneck if I get GTX 1660 Super with my Intel Pentium Gold G5420 processor and everyone said it will not bottleneck and that I shouldnt have a problem but MY FRIEND WHO's 15yrs old thinks that it will bottleneck alot and that he knows better than other people so I need your opinion
https://linustechtips.com/topic/1502065-will-it-bottleneck/
i mean its a dual core CPU, that will be your limitation on the system. But as a balance it should do its job for now until you can get a better one.
https://linustechtips.com/topic/1502065-will-it-bottleneck/#findComment-15901907
I swear to god, the word bottleneck needs to be banned on the forum.
Yes, it will bottleneck.
Every single PC on the planet has bottlenecks.  Every single one.
You cannot build a PC without a bottleneck, and what will be your bottleneck will change with every task you do on the computer.
Those two should work fine together.
https://linustechtips.com/topic/1502065-will-it-bottleneck/#findComment-15901912
It completely depends on what games you are playing and at what resolution and settings.
At higher resolutions and graphics settings, you'll likely be GPU limited and the CPU will be fine. But at low resolutions and settings, the CPU is going to limit you. Then it depends on the type of games you're playing. Some newer AAA titles are very CPU demanding, regardless of graphics settings, so the CPU could limit you there. And for competitive titles where you tend to turn down settings to get as high of FPS as possible, the CPU will also generally be the limiting factor.
I think the issue is primarily that people asking about bottlenecks just throw out the names of two components and ask, in a vacuum, "Will it bottleneck?" which is unhelpful.
If people instead said something like: "I'm going to be playing CoD:Warzone using competitive settings with a Pentium G5420 and GTX 1660 Super. My computer has 16GB of DDR4-2666 memory and my monitor is 1080p 144Hz. Will the CPU bottleneck my GPU? Or is this reasonably balanced for what I'm doing?" Would you still have a problem with the term in that context?
https://linustechtips.com/topic/1502065-will-it-bottleneck/#findComment-15901981
Way less so, but not 0.
An actual bottleneck is "The CPU is never going to be fast enough to keep up with the GPU."  So, regardless of the task the CPU is the limiting factor.  (It was demonstrated a while ago when pairing like...  a 2080 TI and a Core 2 Duo or something, where the CPU straight up couldn't home to feed the GPU enough data.  That's a real bottleneck.)
Anything even reasonably similar in age / performance will be fine overall.
https://linustechtips.com/topic/1502065-will-it-bottleneck/#findComment-15902176
I think your understanding of a bottleneck differs from the understanding most folks have, then. Generally, I see people saying that a CPU is bottlenecking a GPU if the GPU usage is usually below 90% as a result of a CPU limit. They don't think of it in terms that are that extreme.
https://linustechtips.com/topic/1502065-will-it-bottleneck/#findComment-15902181
sorry if I made you mad or something I'm learing about pc and pc components I know a little bit but not too much I'm more like a software guy not a hardware guy but thanks for your opinion
https://linustechtips.com/topic/1502065-will-it-bottleneck/#findComment-15903607
I'm playing like csgo mordhau and some of the games that dont need that strong pc but im planning on playing like FiveM R6 Apex or sum like that also im using 1360x768 resolution cause of my monitor its like a sony tv that can be used as monitor
https://linustechtips.com/topic/1502065-will-it-bottleneck/#findComment-15903611
