Help with plugs
Solved by Jewfishy,
Well, the 24pin needs alot of force to pull out, but try to be a little gently and not to touch the motherboard. And squeeze the little 'catch' that looks over the little triangle to keep it in place. Make sure you are pulling straight up too, wiggling the header slightly may help
derekchan ·
Posted in New Builds and Planning4 -
5
1
5
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting7 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
